I am a beginner in such practical matters as I have never blocked connections or used ARP etc and have blindly used DHCP auto.
Problem: How to prevent users, who have SSID password, from adding additional devices to the network. The password is required for iphone, ipad, access etc… standard usage.
MAC auth, perhaps annoying, is one way. But simple config.
Second, be enable the hotspot feature, it deals with this sort of things. If you follow MT’s hotspot docs… just replace an VLAN interface, instead of a bridge… Might be close to something acceptable. Nothing stops you from putting a password on a hotspot’s SSID to get the encryption. And with wifiwave2, you can use OWE authentication, which is an open network, but runs encrypted WITHOUT needing SSID password.
Third option… use WPA2/3-EAP with user-manager/RADIUS. Similar to hotspot, but phone will prompt for username/password, instead of a popup. And you can do stuff like VLAN assignment based on the user provided, which is added benefit in this approach, using only one SSID. Great for smartphone/desktop, but IoT tougher with this one.
And option 2, /ip/hotspot on a VLAN allow non-Mikrotik Wi-Fi…
FWIW…While /ip/hotspot hasn’t changed, between Wave2’s OWE and a DHCP option that says it’s a hotspot… devices act much better with a captive portal than they did 5+ years ago… And it works on VLAN so easy to try…
Dhcp server with split subnet
A known section with static ips
A pool for those not known, dynamic allocation.
Everything in the dynamic section can be HEAVILY restricted by firewall. Even to the point of being completely blocked. Up to you.
The known addresses are treated more liberal.
I don’t play favorites. Your approach works too… e.g., a white-list in dhcp, with dynamic DHCP being block/“disfavored”, using some address-list in between.
While hotspot does allow you have a “user” that allows one device only to login…a hotspot user can “logout”, and use a different device in the hotspot scheme. Dunno if that be okay here.
Do you have Active Directory running in the environment?
If yes and Access Points do support RADIUS, than maybe (but only maybe, sorry) you can try to use the Windows NPS on AD server to allow only trusted users and devices to join the network.
The rule in NPS will be something like this:
if someone is using Wireless and
his account is in specific AD group like USERS_WIFI_ACCESS and
the device is in specific AD group like DEVICES_WIFI_ACCESS
Than give him access to the network.
If you are not familiar with RADIUS it will be a hard time for sure - just saying.
But these rules are depending on:
accessing to WiFi is possible only by individual user names and passwords (and domain) - not a SSID password,
having authoritary access to any authorized device which can join the network (you need to add them in AD and use MAC addressess as device users and passwords (if I remember it properly) and you need to disable changing this address on devices which have this feature - and this option cannot be changed by the end user himself).
It’s a 802.1X scenario which is possible to obtain for wired connections (if switches do support it), but I’m not sure it can be done on wireless devices.
