I have only a short question it is that Im using this syntax in code:
:local clientcount [:tonum [/interface wireless registration-table print count-only]]
The fail is that the print command after it is executed also prints value to console even if I use as-value command.
Is there any possibility to fix it?
Its only a cosmetic problem but router must print to console so one more action for him.
