Print Command
Hello there
i want to get in print command only the one column results.
ip interface print , BUT to get only the NAME
or
ip hotspot user print , and AGAIN ONLY the usernames
How is that possible?
Thank you!
foreach a in=[/interface find] do={:put [interface get $a name]}
I have a similar question it is not print the output in the terminal , but to the array.
Let’s say ,
:global a [/interface print as-value] , and you will get an array with all the interfaces info,
If I just want to get the names of the interface in the array, how to get it ?
the expected result kind of like: a={ ether1;ether2; .. ; wlan1} or a={ {ether1}; {ether2}; …, {wlan1} }
Thank you !
Not exactly sure what you like to do.
This will get all interface in to array list and then print it:
:local list
 :foreach i in=[find] do={
	:set list ($list,[get $i name])
:put $list
ether1;ether2;ether3;ether4;ether5
I do not think you can use as-value with multi line.
This works
:put ([/system clock print as-value ]->"date")
feb/05/2021
Not OK
:put ([/interface ethernet print as-value ]->"name")
This is exactly what I want. I tried with “print as-value” but no luck. Looks like it is not possible to “print as-value” for only one properties/field.
Thank you !
