print from one vlan to another?
Hello everyone
I have tried searching google to find a solution to print over 2 vlan but did not make anything work :frowning:
I have 2 Vlan:
VLAN5 = a small domain
VLAN2 = A hotspot network with a hotspot server (Non-mikrotik)
My whole network is cisco switches and all wifi and more are mikrotik, no probelm :slight_smile:
I have a shortage of microtik routers so this is also not a problem.
Well I need to have a router on the network so I can print from VLAN2 HOTSPOT to VLAN5 DOMAIN
My hotspot ip is 10.20.7.0/24 and domain is 10.0.0.0/24
Printer to add is 10.0.0.240 - 10.0.0.241 - 10.0.0.242 - 10.0.0.243
Is there anyone who can tell me how to set up a so-called print router so I can print from VLAN2 hotspot to these printers on VLAN5 DOMAIN?
Router setup should be simple setup? then there is the firewall that I have a lot of doubt about, so itโ€™s only print for these printers that I open for?
Hope it is possible?
Regards
Jimmy
Are those 2 VLAN (Subnets) configured in the same router?
Hello ingdak
Yes right now I have gone back to a simple router where my vlan5 domain is so called wan and my vlan2hotspot is on lan, and have not created anything else now.
just to make sure, my 2 VLANs are completely independent lan with their own gateway, dhcp and everything that belongs.
I have currently set up the dhcp client in router from both WAN (domain) and lan (hotspot) to start with.
Regards
Jimmy
If you do NAT between 2 Subnets you cannot do access IP from one subnet to other one! The should just to be routed to each other!
Ok i remove nat bug what shout that help?
Do i nede to make a one to one nat maybe?
Andy have a code example maybe ?
