Print simple queues
Is there a way to print all my simple queues to a printer? Either via a dump in a .txt file or copy and paste into a .doc or better, .xls file? Or straight print?
In winbox I can only print a screen dump. This will only give me the queues I can manage to get into the visible window…
In terminal I get all the settings of each queue which gives me a messy overview. I only want to print name, target address and the comment, all in one line.
In webGui I can’t seem to edit the way the queues are presented. So to do a print out I need 24 (!) pages A4 for only 300 queues! Each queue uses two lines since the command is written above the queue data which is a waist of space.
There must be a better way to have a print out produced for all the (simple-) queues?
Anybody?
To dump print output to text file use:
print file=filename.txt
Then format it according to your needs.
HTH,
