Prism card problems
I updated my tower to RouterOS v3.rc3 recently. One of my cards is an engenius prism 2.5 card. For some reason, about once an hour, the card stops responding and all the customers registered to that card are lost. I can look at the card via winbox and if I try to run a scan or frequency usage, nothing happens. Disabling and enabling the card does nothing. If I reboot the router it comes back up for about an hour then it freezes again. I set up a watchdog restart when a specific customer is lost so Im up for now, but dont know what the problem is. HELP
you should make the support output file when the wireless card doesn’t work and send it to support@mikrotik.com
what is the command to do that please?
Please reat this:
http://www.mikrotik.com/testdocs/ros/2.9/system/support.php
I hope is understood my English.
To my I go, I have two plates PRISM, but one walked single, other no.
I had to return to version 2.9.46.
