We are nusing a senao prism 200mW mPCI to connect to a Cisco Aironet 350 Bridge.
The bridge is setup in Ap/Root-Bridge mode but MT2.9.18 will not connect to the bridge.
Our signal is -77dBm average and SCAN show the ssid of the AP/Root Bridge.
We were able to test the MT router and make it connect to a client while in AP/Bridge mode before upgrading to 2.9.18 from 2.9.12
Aironet Allow propretiary extension is off
Enscapulation method set to RFC1042
Can the upgrade be our problem.
Because now the MT does not connect to any station even in AP mode.
Is it possible to downgrade to 2.9.12 and how do I get the version to download.
Just tested and we got it to work without any problems. We used Cisco AIR-BR350 with firmware 12.03T.
Prism card connected and were able to pass data.
When you are scanning do you see the Cisco ssid?
Enable the debug wireless logging, make the support output file and send it to support@mikrotik.com
I am not sure. If you can get newer firmware you can try to update.
Make that support output file when the debug logging is enabled and send it to supprt@mikrotik.com
what is the distance between the card and the Cisco bridge?
enable the wireless deug logging, look in the log file when it tries to connect and then make the support output file and send it to support@mikrotik.com
