Someone wrote a python script to generate a Wireguard config file using PIA credentials and a chosen region:
https://github.com/hsand/pia-wg
I took that and added some features to it a while ago, along with a new script to send a Wireguard config to RouterOS:
https://github.com/kchiem/pia-wg
NOTE: The Wireguard config to RouterOS script can be used for any vpn, not just PIA.
Usage is documented at the url above, and as mentioned, it’s up to you from there on to decide what traffic you want to route through the new interface. Here’s an example on how to do split tunneling and only route certain destinations through the vpn:
- Create an address list for the sites you want to route through the vpn:
/ip/firewall/address-list/add list=vpn-list address=wtfismyip.com
(add an entry for each destination you want to use the vpn)
- Mark your connections and packets:
a. mark the connections to the address list above with the connection mark “vpn-connections”
/ip/firewall/mangle/add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-list=vpn-list new-connection-mark=vpn-connections
b. mark your packets from those connections with the routing mark “vpn-routing”
/ip/firewall/mangle/add action=mark-routing chain=prerouting connection-mark=vpn-connections in-interface-list=bridge-local new-routing-mark=vpn-routing
- Route marked packets to the new interface:
a. create a new routing table to use
/routing/table/add fib name=vpn-table
b. add a route for the routing table above (using the new interface from the example in the url, wg-pia-il)
/ip/route/add check-gateway=none distance=1 dst-address=0.0.0.0/0 gateway=wg-pia-il routing-table=vpn-table
c. add a rule for packets with a routing mark of “vpn-routing” to use the routing table “vpn-table”
/routing/rule/add action=lookup routing-mark=vpn-routing table=vpn-table
- Make sure traffic out of that interface is NAT’ed. I use an interface list to NAT all my WAN ports like:
/interface/list/add name=WAN
/interface/list/member/add interface=wg-pia-il list=WAN
/ip/firewall/nat/add action=masquerade chain=srcnat out-interface-list=WAN
But you could also do it per-interface:
/ip/firewall/nat/add action=masquerade chain=srcnat out-interface=wg-pia-il
Now if you point your browser to wtfismyip.com, or run:
curl http://wtfismyip.com/text
it should return an IP from the VPN.
