I have configure my syslog server on Ubuntu from RB2011 UiAS. Here Static IP logs are stored properly, But Private IP logs are not working properly ( cant see private IPs source and destination paths).
What kind of log entry are you missing in particular?
Either that kind of logging is not enabled by default or is not possible to log at all (due to numerous reasons).
Without you being very specific when describing the issue here we can not help (mind readers are on the other forum).
I want to get log from customer browsing websites and its path of IP travelling.
Here i have use srcnat for my Private IPs, When i want to trace my Private IPs logs, It shows me 0.0.0.0 as source IP and 255.255.255.255 as destination IP. How can i rectify this?
Please help me from this issue.
and you should push it near the start of filter list - exact place really depends on other chain=forward rules … definitely above rule that might look like this one:
The rule will only show connections from inside your LAN towards internet. Depending on topology of your LAN(s) rule to log browsing between LAN(s) hosts would look alike … some connections won’t show as they don’t pass router at all (i.e. if server is in the same subnet as client).
