Private or public IPs on WISP Hotspot APoints?
Hi
I am planning to set up mid size hotspot with aroun 10 to 20 APoints. What would be the IP plan with pubic and private ips? Will this work?
So here’s the plan:
Main Internet Router
Rocket M5 AP-WDS ( Future plan to use OSPF subnet of /30 or 32 for routing between Hotspot AP to gateway)
Wireless backhaul link
Rocket M5 STA-WDS ( Future plan to use OSPF subnet of /30 or 32 for routing between Hotspot AP to gateway)
[main repeater mast]
Rocket M5 Sector AP-WDS (Future plan to use OSPF subnet of /30 or 32 for routing between Hotspot AP to gateway)
Customer wireless links
Nanostation M5 STA-WDS
Natostation M5 STA-WDS
Example IP address plan:
Internet Router: public IP address http://www.xxx.yyy.zzz
MT 433AH Hotspot: private IP e.g. 192.168.0.100
MT 433AH Hotspot: private IP e.g. 192.168.0.101
MT 433AH Hotspot: private IP e.g. 192.168.0.102
Nanostation Hotspot: private IP e.g. 192.168.0.200
Customer’s Ethernet router: public IP e.g. http://www.xxx.yyy.zz2
MT 433AH Hotspot: private IP e.g. 192.168.0.201
Customer’s Ethernet router: public IP e.g. http://www.xxx.yyy.zz3
Will this work?
I have two questions for you:
1: Are you doing a question in the Mikrotik forum about a 100% Ubiquity networks network?
2: this is a joke? xD
Is it ok now?
