MLPPP bug when using greater than 2 links regardless if its over 3 seperate physical links or over the same single physical link!
When you set PPPoe client with 3 interfaces either it being the same interface, or 3 seperate interfaces, once you get to the 3rd link, the bundle no longer functions
You can get ping packets out that are greater than 60 large, but small packets cannot leave, and you cannot establish connection from outside to the bundle IP address.
Also MTU always reports 32719 regardless of setting
anyone else confirm! I really needed this to work!
I tried with two routers in two different locations and results are identical and easy to reproduce!
Works perfectly with 2 PPPoE DSL Links
