Probably loop
Hi everyone,
I am new to this mikrotikforum and have a question that hopefully someone can help with.
I was using mikrotik CCR1009-8G-1S-1S+ for a couple of years and decided to upgrade from v6.38.5 to 6.44.6
After doing that I keep getting this logmessage “TrunkToSwitch_02-alternate: bridge port received packet with own address as source address (00:00:10:00:00:00), probably loop”. I also see that my network is really unstable after the upgrade.
I am using RSTP and VRRP. The standby router has a huge amount of packetloss and shows no warnings what so ever in the logs. The logmessage comes from the master Mikrotik.
Does anyone knows what seems to be the problem?
Help will be very appericiated!
Hey. Since RouterOS v6.41 there is no such feature like master and slave ports. All these thing were change to simple bridge and hardware interfaces in it with hardware offloading:
https://wiki.mikrotik.com/wiki/Manual:Master-port
I think you should make an audit of your interfaces connected to a bridge with vrrp in it.
