I am new to the forum, with intermediate network skills and relatively new with the mikrotik devices(1 year of experience)
To the point…i have a 912UAG-5HPnD device installed and i would like your opinion.
The device is configured as WISP AP in bridge mode and there are 5 clients connected (5-10km each)
I have upgraded to the 6.35.2 version.
The network logical setup is like : Gateway Router -->PtP Link–>switch–>912UAG-5HPnD–>5 clients connected
It’s in a remote location so there is a dedicated point to point link which passes the traffic through a switch to 912UAG-5HPnD and from there to the clients.
The problem is that at the logfile of 912UAG-5HPnD i get "memory interface,warning ether1:bridge port received packet with own address as source address (4c:5e:0c:88:9b:b8), probably loop)
I get this warning every 6 seconds and the device is half unresponsive(50% packet loss and winbox takes 2-3 minutes to open). The clients do not realize a problem since traffic passes through the device. I ping from the gateway router the 912UAG-5HPnD with 50% packet loss but the clients connected to 912UAG-5HPnD with 0% packet loss.
The point to point link is WDS enabled so is the 912UAG-5HPnD.
Rstp is enabled and i have tried to change Admin MAC Address at the bridge interface as i have read to another post in the forum but to no avail.
So could it be something else in the configuration of the device, or a mistake at the configuration causing this warning?
Or should i search for a real loop in the network?
Thank you in advance
Tasos
