probe user manager
Good day
Does dude have a probe for user manager ? I see there is one for radius which works fine with free radius but nothing for user manager
which service exactly are you interested in? if you just want to know if user manager is working, you can check the www service, or any other service which is running on that machine.
you can also make a new probe with the function “roscommand” which would connect to the router and execute some RouterOS command and await a specific result …
Hi normis
A similar probe as the radius, sometimes i need to restart the user manager server due to clients that can not authenticate and i prefer to know that it is not working before the client knows.
Can you recommend a roscommand ?
