It’d be nice to set a timeout for an individual probe like say, PING (icmp echo) so if ping times exceed an established minimum you get some sort of notification. Right now it looks like you can only specify probe timeouts in seconds, and for the entire map, or you have to do it for every single device…
That is in the work. Maybe there will be a new release Wednesday. If not, it will be the next Wednesday and then every Wednesday after that.
John
Good to hear, keep up the good work!
