Problem about connect to iPhone personal hotspot
Hi everyone, I searched the whole forum but didn’t find any answer in my case, so write this new post.
My place may have wire internet issue sometimes, and I usually share my mobile internet to router so that keep connect to internet temperately b4 telecom services come and fix.
Used to do this on Android phones, no issue on both wifi or USB tethering.
Since I swap to RB4011iGS+5HacQ2HnD-IN, WIFI tethering is the only way.
And I found that my router was nearly impossible to connect iPhone personal hotspot, means router can’t find iPhone sharing SSID signal.
On iPhone 12, router can connect to it by enabling “Maximize capability” in settings, otherwise router just can’t find it.
But for older iPhone like iPhone X didn’t have this option to enable.
So I’m curious. What difference between enable/disable “Maximize capability”, and how could I let router found iPhone tethering while no options?
Model: RB4011iGS+5HacQ2HnD-IN (non-US model)
RouterOS version: 6.49
iOS version: 14.5.2 & 15.1
Many thanks.
it just works
[user@951G-2Hnd] > /export
# apr/14/2022 22:49:43 by RouterOS 7.3.1
# model = 951G-2HnD
add admin-mac=(BRIDGE MAC ADDRESS) auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] supplicant-identity=951G-2Hnd
add authentication-types=wpa2-psk mode=dynamic-keys name=anotherHotspot supplicant-identity=""
add authentication-types=wpa2-psk mode=dynamic-keys name=iphone supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=poland disabled=no distance=indoors installation=indoor security-profile=iphone ssid=\
    "iPhone6S" wireless-protocol=802.11
add address-pool=default-dhcp interface=bridge name=defconf
add comment=defconf interface=wlan1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.2,1.1.1.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Warsaw
/tool mac-server
/tool mac-server mac-winbox
wireless interface
[user@951G-2Hnd] > /interface wireless print
Flags: X - disabled; R - running
 0  R name="wlan1" mtu=1500 l2mtu=1600 mac-address=8B:B8:BB:91:1B:BC arp=enabled interface-type=Atheros AR9300 mode=station ssid="iPhone6S"
      frequency=2412 band=2ghz-b/g/n channel-width=20mhz secondary-frequency="" scan-list=default wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1
      wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes
      default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=iphone compression=no
wireless security profiles
[user@951G-2Hnd] > /interface wireless security-profiles print
Flags: * - default
 0 * name="default" mode=none authentication-types="" unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=""
     supplicant-identity="951G-2Hnd" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none mschapv2-username="" mschapv2-password=""
     disable-pmkid=no static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none
     static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no radius-mac-accounting=no
     radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-called-format=mac:ssid
     radius-mac-caching=disabled group-key-update=5m management-protection=disabled management-protection-key=""
 1   name="anotherHotspot" mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key=""
     wpa2-pre-shared-key="(YOUR WIFI PASSWORD)" supplicant-identity="" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none
     mschapv2-username="" mschapv2-password="" disable-pmkid=no static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none
     static-key-2="" static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key=""
     radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX
     radius-mac-mode=as-username radius-called-format=mac:ssid radius-mac-caching=disabled group-key-update=5m management-protection=disabled
 2   name="iphone" mode=dynamic-keys authentication-types=wpa2-psk unicast-ciphers=aes-ccm group-ciphers=aes-ccm wpa-pre-shared-key=""
     wpa2-pre-shared-key="(YOUR WIFI PASSWORD)" supplicant-identity="" eap-methods=passthrough tls-mode=no-certificates tls-certificate=none mschapv2-username=""
     mschapv2-password="" disable-pmkid=no static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2=""
     static-algo-3=none static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key="" radius-mac-authentication=no
     radius-mac-accounting=no radius-eap-accounting=no interim-update=0s radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
     radius-called-format=mac:ssid radius-mac-caching=disabled group-key-update=5m management-protection=disabled management-protection-key=""
