Problem accessing Public addresses of same subnet
Work with this configuration for years and only recently noticed that i cant access
webpages having IPs of the same subnet as mine, as :
ISP given IP address: XX.XX.XX.100
Cant access other adresses, like: XX.XX.XX.222
Pinging gives “Destination host unreachable”
Configuration:
RouterOS v3.28
LAN 192.168.2.X
WAN XX.XX.XX.100
Using NAT/Masquerade
[admin@MikroTik] /ip address> pri
#   ADDRESS            NETWORK         BROADCAST       INTERFACE
0   192.168.2.1/24     192.168.2.0     192.168.2.255   ether2
1   XX.XX.XX.100/24  XX.XX.XX.0    XX.XX.XX.255  ether1
[admin@MikroTik] /ip route> pri
#      DST-ADDRESS        PREF-SRC        GATEWAY-STATE GATEWAY              DISTANCE INTERFACE
0 A S  0.0.0.0/0                          reachable     XX.XX.XX.1         1        ether1
1 ADC  192.168.2.0/24     192.168.2.1                                        0        ether2
2 ADC  XX.XX.XX.0/24    XX.XX.XX.100                                     0        ether1
Whats wrong in configuration, or i need something to add? Thanks
