Problem adding R52H to RB411U
Hi!
I’ve added new R52H to my RB411U (Level4) with 5.16 firmware
I can see IRQ
 /system resource pci> print
 # DEVICE   VENDOR                        NAME                              IRQ
 0 00:12.0  Atheros Communications Inc.   AR5413 802.11abg NIC (r...         48
but not interface
 /interface> print
 #     NAME                             TYPE               MTU L2MTU  MAX-L2MTU
 0  R  ether1                           ether             1500  1526       1526
other test:
  • Downgrate to 5.12 not resolve the problem
  • Adding/Removing 3G modem not change R52H interface status
  • Reset configuration (to default) not solve the problem
Can you help me?
During boot, if R52H is connected, I can see this by serial port:
jumping to kernel code
Starting...
Starting services...
Oops[#1]:
Cpu 0
$ 0   : 00000000 00000064 d1320000 deadc0de
$ 4   : 000000c8 00004d58 ffffffff c03bebac
$ 8   : c03c2c65 00000000 000000bc 00000000
$12   : 00000000 080072ff 080072df 6e637920
$16   : c1f70000 00000002 fffcffff 00000064
$20   : 00010000 c1f74470 0000005a c1f70080
$24   : 00000003 00000000
$28   : c1f6c000 c1f6dc58 00450000 c1faabf0
Hi    : 000000bc
Lo    : a1d80000
epc   : c1faabfc a5212_swba_int+0x382c/0x4a08 [a5212@0xc1fa0000]
    Tainted: P
ra    : c1faabf0 a5212_swba_int+0x3820/0x4a08 [a5212@0xc1fa0000]
Status: 1000c603    KERNEL EXL IE
Cause : 1080001c
PrId  : 00019374 (MIPS 24Kc)
Process insmod (pid: 236, threadinfo=c1f6c000, task=c085c450, tls=00000000)
Stack : 00010000 000000d0 00438a4c 00010000 c1f70000 00000013 00000013 00000000
        00000000 c1fab5a0 000000d0 00000041 d0000000 00000000 00000001 00000034
        10000000 00000000 00000000 00000000 c1f70000 00000000 00000000 c1fac4dc
        10000000 c1f74470 0000005a c1f70080 00000000 c02f9a54 10000000 c010ffdc
        c1f70000 c1f70080 00000002 d1320000 10000000 c1fa20a0 00000000 0000000a
Call Trace:
[<c1faabfc>] a5212_swba_int+0x382c/0x4a08 [a5212@0xc1fa0000]
[<c1faabf0>] a5212_swba_int+0x3820/0x4a08 [a5212@0xc1fa0000]
Code: 8e020a18  26310001  8c434004 <00721824> ac434004  5633fff4  8e020a18  3c0
---[ end trace dfde3d450a918355 ]---
Netfilter messages via NETLINK v0.30.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
MikroTik 5.16
MikroTik Login: ctnetlink v0.93: registering with nfnetlink.
ip6_tables: (C) 2000-2006 Netfilter Core Team
usbcore: registered new device driver usb
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
rb400-ohci rb400-ohci.0: RB400 OHCI
rb400-ohci rb400-ohci.0: new USB bus registered, assigned bus number 1
rb400-ohci rb400-ohci.0: irq 22, io mem 0x1c000000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ip_tables: (C) 2000-2006 Netfilter Core Team
usb 1-2: new full speed USB device using rb400-ohci and address 2
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not aftr
ath chip revision: 000000a8
rb400-ehci rb400-ehci.0: RB400 EHCI
rb400-ehci rb400-ehci.0: new USB bus registered, assigned bus number 2
rb400-ehci rb400-ehci.0: irq 3, io mem 0x1b000000
rb400-ehci rb400-ehci.0: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ar724x_usb: Host Tx Pre-Buffer Packet Tuning [00000000]
usb 1-2: can't set config #1, error -62
usb 1-2: USB disconnect, address 2
netfilter PSD loaded - (c) astaro AG
hub 2-0:1.0: unable to enumerate USB device on port 2
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usb 1-2: new full speed USB device using rb400-ohci and address 3
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for Sierra USB modem
sierra 1-2:1.0: Sierra USB modem converter detected
usb 1-2: Sierra USB modem converter now attached to ttyUSB0
usb 1-2: Sierra USB modem converter now attached to ttyUSB1
usb 1-2: Sierra USB modem converter now attached to ttyUSB2
usbcore: registered new interface driver sierra
sierra: v.1.7.16:USB Driver for Sierra Wireless USB modems
rb400_beep 5000
rb400_beep 0
rb400_beep 5000
rb400_beep 0
rb400_beep 0
reset ag7100
eth0: reset unit 0 (phy 1)
eth0: open
skb_bin_request: add eth0 1526 1622
eth0: link down
and without any operation this is the “console” abnormar output:
alg: No test for ecb(cipher_null) (ecb-cipher_null)
alg: No test for digest_null (digest_null-generic)
alg: No test for compress_null (compress_null-generic)
NET: Registered protocol family 15
mpls_nl_init: id 17
fan: init
rb_ioctl, cmd: 0x1, arg: 0x0
rb: RB_CFG_SIZE
rb_ioctl, cmd: 0x3, arg: 0x4208d0
rb: RB_READ_CFG
rb_ioctl, cmd: 0xf, arg: 0x0
rb: RB_GET_TYPE
rb_ioctl, cmd: 0x2, arg: 0x0
rb: RB_INFO_SIZE
rb_ioctl, cmd: 0x4, arg: 0x4218d8
rb: RB_READ_INFO
same problem with 6.0beta2
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
Starting...
MikroTik 6.0beta2
MikroTik Login: Oops[#1]:
Cpu 0
$ 4   : 000000c8 00004d58 ffffffff c03d5b9c
$ 8   : c03d9c55 00000000 0000006a 00000000
$16   : c1fb0000 00000002 fffcffff 00000064
$20   : 00010000 c1fa4470 0000005a c1fb0080
$28   : c1f96000 c1f97bb8 00000028 c09cad50
Hi    : 0000006a
Lo    : b62a0000
epc   : c09cad5c a5212_swba_int+0x3830/0x4a0c [a5212@0xc09c0000]
    Tainted: P
ra    : c09cad50 a5212_swba_int+0x3824/0x4a0c [a5212@0xc09c0000]
Cause : 1080001c
Process insmod (pid: 239, threadinfo=c1f96000, task=c1c27398, tls=00000000)
Stack : 00010000 000000d0 00000124 00010000 c1fb0000 00000013 00000013 00000000
        00000000 c09cb700 000000d0 00000041 d0000000 00000000 c03a4260 10000000
        00000001 00000000 00000000 00000000 c1fb0000 00000000 00000000 c09cc640
        10000000 c1fa4470 0000005a c1fb0080 00000000 c0317f68 fffffffb c011050c
        c1fb0000 c1fb0080 00000002 d1320000 10000000 c09c20dc c011f1e0 0000000a
Call Trace:
[<c09cad5c>] a5212_swba_int+0x3830/0x4a0c [a5212@0xc09c0000]
[<c09cad50>] a5212_swba_int+0x3824/0x4a0c [a5212@0xc09c0000]
Code: 8e020a24  26310001  8c434004
 ac434004  5633fff4  8e020a24  3c04c09d  0c0c5fd2
---[ end trace 21a2192f8e603ec8 ]---
usb 1-2: new full speed USB device number 2 using rb400-ohci
Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
usb 1-2: USB disconnect, device number 2
rb400_beep 5000
rb400_beep 0
rb400_beep 5000
rb400_beep 0
usb 1-2: new full speed USB device number 3 using rb400-ohci
rb400_beep 0
reset ag7100
eth0: open
eth0: link down
eth0: reset phy 0
eth0: link up
eth0: phy speed: 100, fdx: 1
rb: RB_CFG_SIZE
rb: RB_READ_CFG
rb: RB_GET_TYPE
rb: RB_INFO_SIZE
rb: RB_READ_INFO
:frowning: :open_mouth: :confused:
please email supout.rif file to support, we will see what fails there.
Hello
I’ve solved today changing the card with another.
Thanks for you support!
Regards
