There was a big storm in my city… after that some clients could not connect to my AP… what could have happened?
i have checked this:
*clients ants are aligned
*clients ap are working
*clients that can’t connect can’t see my ssid, but can see other ssid and can connect to them
*some clients can connect to my ap and see my ssid
i have a RB532 with an SR2…
The problem is in my SR2 ?? my ant???
before the storm everything was working fine
It could be water in the co-ax / antenna blown in by high winds or (more likely if it was an electrical storm) the SR2 radio’s front end killed by a close lightning strike. I’ve had the latter happen to 3 of my APs this year, I will be installing lightning protection as soon as I can afford it. I think of the effect as somehow making the AP muffuled so only some clients will work.
yes it was a lighning storm… the most powerfull of this year…
if I change from Antenna A to Antenna B in Antenna Mode… and obviously connect the omni ant to the other connector in the SR2… do i have any probability to solve my problem? or if antenna A is down, antenna B is down too¿¿?
