Problem after the update to 6.20 and 6.22 in the PPP
i have Problem after the update to 6.20 and 6.22 in the PPP
I use this line of script :
:local newIP [/ip address get [find interface=“PPPoE 1”] address];
Previously if you are connected to the value of the variable ($newIP) is External IP
And if it is not connected, the value Internal IP like “192.168.2.10”
but after the update to 6.20 and 6.22
If it is not connected to be without value and not work script ???
example this script :
/system script add name=“PPPoEmonitorIPchange” source={
:global currentIP1;
:global newIP1 [/ip address get [find interface=“pppoe-ISP1”] address];
:if ($newIP1 != $currentIP1) do={
:put “ip address $currentIP1 changed to $newIP1”;
:set currentIP1 $newIP1;
:if ([:pick $newIP1 0 8] = “192.168.”) do={
/tool e-mail send to=“mypersonalemail@gmail.com” subject=(“Disconnected - ISP1”) body=(“$currentIP1”)
} else={
/tool e-mail send to=“mypersonalemail@gmail.com subject=([/ip address get [find where interface=“pppoe-ISP1”] address] . " - ISP1”) body=(“$currentIP1”)
/system scheduler add name=IPcheck interval=1m on-event=PPPoEmonitorIPchange
UP This Post …
Please Help Me …
Hi rftnon
I used this to mail on 6.22, Hope this helps you.
/tool e-mail send from=MYUSER@gmail.com to=TOUSER@gmail.com subject="Hello" body="Hi and Hello" server=173.194.67.108 port=587 start-tls=yes user=MYUSER@gmail.com password=******
Bigfoot
Thank you dear
But that’s not my problem
