Hi
i have problem of communictation point to point
my network is
INTERNET --Router ----AP1 -------REPEATER -------- AP2
AP1
1wlan mode ap-bridge (connected to wlan1 repeater)
1eth
brige1
REPEATER
wlan1
wlan2
1eth
bridge1
AP2
wlan1 connected to wlan2 repeater
eth1
bridge1
if I connected to eth1 of repeater , i navigate safely on the Internet.But if connected to eth1 to AP2 i only navigate up to the router, but not on Internet.
Why?
Hello fren,
yes, you can do as repeater.
i just confirm you better you will set ap1 and ap2 as ap2ap, that's method will easy make roaming for.
how to make it:
every ap must support wds and put it wds on bridge.
this post we sent like that network method. cause we must have roaming for supply our customer as hotspot, pppoe from our centralized AAA. nice...
Again, thanks Mikrotik and Teams, you give us easy for control them, we are on 2,4ghz-b band frequency: center-band signal: -46~48 db distance: 5,5km. this day is saturday 12th January, 2008 13:03 [GMT:+08:00 Bali Indonesian Time] and starting new roaming area.
Ok I must add a wds interface and enter in on each bridge AP?
hai fren,
yes, you can add bridge and wds interfaces each ap, than set your ap to ap-bridge mode, set wds-mode=static and put other wds on connect-list when default-authentication=no and default-forwarding=no for stopping commnucation each other.
wds mode must same band, freq and put management address for. it will build roamning network.
