Problem building metarouter packages
I’m need to compile zabbix proxy for mikrotik metarouter, but I’m starting with something easier for now.
I’m trying to follow “OpenWrt Wiki » Documentation » HOWTOs » Using the SDK” tutorial for build metarrouter ipk package of nano and test it in RB450G.
Tutorial is here:
http://wiki.openwrt.org/doc/howto/obtain.firmware.sdk
1- download and uncompress the openwrt SDK for metarouter architecture: OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32
Download from URL: http://rnd.rajven.net/openwrt/mikrotik/metarouter/mr-mips/
Uncompress in /home/leo/Documentos/openwrt/
Next I type: cd /home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32
2- download package definitions for nano ->OK:
svn export svn://svn.openwrt.org/openwrt/packages/utils/nano package/nano
3- download package definitions for ncurses ->OK:
svn export svn://svn.openwrt.org/openwrt/trunk/package/libs/ncurses package/ncurses
4- I tried to compile ncurses → FAIL:
make package/ncurses/compile
Collecting package info: done
Collecting target info: done
Checking 'working-make'... ok.
Checking 'case-sensitive-fs'... ok.
Checking 'getopt'... ok.
Checking 'fileutils'... ok.
Checking 'working-gcc'... ok.
Checking 'working-g++'... ok.
Checking 'ncurses'... ok.
Checking 'zlib'... ok.
Checking 'gawk'... ok.
Checking 'flex'... ok.
Checking 'unzip'... ok.
Checking 'bzip2'... ok.
Checking 'patch'... ok.
Checking 'perl'... ok.
Checking 'python'... ok.
Checking 'wget'... ok.
Checking 'git'... ok.
Checking 'gnutar'... ok.
Checking 'svn'... ok.
Checking 'gnu-find'... ok.
Checking 'getopt-extended'... ok.
Checking 'non-root'... ok.
make[1] package/ncurses/compile
make[2] -C package/ncurses compile
make -r package/ncurses/compile: build failed. Please re-run make with V=99 to see what's going on
make: *** [package/ncurses/compile] Error 1
5- Then I tried to compile ncurses with V=99:
make package/ncurses/compile V=99
make[1]: Entering directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32'
make[2]: Entering directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/package/ncurses'
CFLAGS="-Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fhonour-copts -msoft-float -fpic  -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/include " CXXFLAGS="-Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fhonour-copts -msoft-float -fpic  -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/include " LDFLAGS="-L/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/usr/lib -L/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/lib -L/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/usr/lib -L/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/lib " make  -j2 -C /home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9/. AR=mips-openwrt-linux-uclibc-ar AS="mips-openwrt-linux-uclibc-gcc -c -Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fhonour-copts -msoft-float -fpic" LD=mips-openwrt-linux-uclibc-ld NM=mips-openwrt-linux-uclibc-nm CC="mips-openwrt-linux-uclibc-gcc" GCC="mips-openwrt-linux-uclibc-gcc" CXX="mips-openwrt-linux-uclibc-g++" RANLIB=mips-openwrt-linux-uclibc-ranlib STRIP=mips-openwrt-linux-uclibc-strip OBJCOPY=mips-openwrt-linux-uclibc-objcopy OBJDUMP=mips-openwrt-linux-uclibc-objdump SIZE=mips-openwrt-linux-uclibc-size CROSS="mips-openwrt-linux-uclibc-" ARCH="mips" BUILD_CC="gcc" HOSTCC="gcc" HOSTCCFLAGS="" libs ;
make[3]: Entering directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9'
cd include && make -w --jobserver-fds=3,4 -j -- HOSTCCFLAGS= HOSTCC=gcc BUILD_CC=gcc ARCH=mips CROSS=mips-openwrt-linux-uclibc- SIZE=mips-openwrt-linux-uclibc-size OBJDUMP=mips-openwrt-linux-uclibc-objdump OBJCOPY=mips-openwrt-linux-uclibc-objcopy STRIP=mips-openwrt-linux-uclibc-strip RANLIB=mips-openwrt-linux-uclibc-ranlib CXX=mips-openwrt-linux-uclibc-g++ GCC=mips-openwrt-linux-uclibc-gcc CC=mips-openwrt-linux-uclibc-gcc NM=mips-openwrt-linux-uclibc-nm LD=mips-openwrt-linux-uclibc-ld AS=mips-openwrt-linux-uclibc-gcc\ -c\ -Os\ -pipe\ -mips32\ -mtune=mips32\ -fno-caller-saves\ -fhonour-copts\ -msoft-float\ -fpic AR=mips-openwrt-linux-uclibc-ar DESTDIR="" libs
make[4]: Entering directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9/include'
make[4]: Nothing to be done for `libs'.
make[4]: Leaving directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9/include'
cd ncurses && make -w --jobserver-fds=3,4 -j -- HOSTCCFLAGS= HOSTCC=gcc BUILD_CC=gcc ARCH=mips CROSS=mips-openwrt-linux-uclibc- SIZE=mips-openwrt-linux-uclibc-size OBJDUMP=mips-openwrt-linux-uclibc-objdump OBJCOPY=mips-openwrt-linux-uclibc-objcopy STRIP=mips-openwrt-linux-uclibc-strip RANLIB=mips-openwrt-linux-uclibc-ranlib CXX=mips-openwrt-linux-uclibc-g++ GCC=mips-openwrt-linux-uclibc-gcc CC=mips-openwrt-linux-uclibc-gcc NM=mips-openwrt-linux-uclibc-nm LD=mips-openwrt-linux-uclibc-ld AS=mips-openwrt-linux-uclibc-gcc\ -c\ -Os\ -pipe\ -mips32\ -mtune=mips32\ -fno-caller-saves\ -fhonour-copts\ -msoft-float\ -fpic AR=mips-openwrt-linux-uclibc-ar DESTDIR="" libs
make[4]: Entering directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9/ncurses'
mips-openwrt-linux-uclibc-gcc -DHAVE_CONFIG_H -I../ncurses -I. -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/include  -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64  -DNDEBUG -I. -I../include -Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fhonour-copts -msoft-float -fpic   --param max-inline-insns-single=1200 -fPIC -c ../ncurses/./tty/hardscroll.c -o ../obj_s/hardscroll.o
mips-openwrt-linux-uclibc-gcc -DHAVE_CONFIG_H -I../ncurses -I. -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/target-mips_uClibc-0.9.32/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/staging_dir/toolchain-mips_gcc-4.5-linaro_uClibc-0.9.32/include  -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64  -DNDEBUG -I. -I../include -Os -pipe -mips32 -mtune=mips32 -fno-caller-saves -fhonour-copts -msoft-float -fpic   --param max-inline-insns-single=1200 -fPIC -c ../ncurses/./tty/hashmap.c -o ../obj_s/hashmap.o
In file included from ../ncurses/./tty/hardscroll.c:148:0:
../ncurses/curses.priv.h:886:2: error: expected specifier-qualifier-list before 'NCURSES_SP_OUTC'
../ncurses/curses.priv.h:1129:2: error: expected specifier-qualifier-list before 'NCURSES_SP_OUTC'
../ncurses/curses.priv.h:1892:63: error: expected declaration specifiers or '...' before 'NCURSES_OUTC'
../ncurses/./tty/hardscroll.c:185:1: error: 'NCURSES_SP_NAME' declared as function returning a function
../ncurses/./tty/hardscroll.c: In function 'NCURSES_SP_NAME':
../ncurses/./tty/hardscroll.c:206:35: error: called object 'NCURSES_SP_NAME(&_nc_hash_map)' is not a function
../ncurses/./tty/hardscroll.c:237:35: error: called object 'NCURSES_SP_NAME(&_nc_scrolln)' is not a function
../ncurses/./tty/hardscroll.c:271:35: error: called object 'NCURSES_SP_NAME(&_nc_scrolln)' is not a function
make[4]: *** [../obj_s/hardscroll.o] Error 1
make[4]: *** Waiting for unfinished jobs....
In file included from ../ncurses/./tty/hashmap.c:70:0:
../ncurses/./tty/hashmap.c:276:1: error: 'NCURSES_SP_NAME' declared as function returning a function
../ncurses/./tty/hashmap.c:415:1: error: 'NCURSES_SP_NAME' declared as function returning a function
../ncurses/./tty/hashmap.c:415:1: error: redefinition of 'NCURSES_SP_NAME'
../ncurses/./tty/hashmap.c:276:1: note: previous definition of 'NCURSES_SP_NAME' was here
../ncurses/./tty/hashmap.c: In function 'NCURSES_SP_NAME':
../ncurses/./tty/hashmap.c:418:19: error: 'i' undeclared (first use in this function)
../ncurses/./tty/hashmap.c:418:19: note: each undeclared identifier is reported only once for each function it appears in
../ncurses/./tty/hashmap.c: At top level:
../ncurses/./tty/hashmap.c:430:1: error: 'NCURSES_SP_NAME' declared as function returning a function
../ncurses/./tty/hashmap.c:430:1: error: redefinition of 'NCURSES_SP_NAME'
../ncurses/./tty/hashmap.c:438:52: error: 'bot' undeclared (first use in this function)
../ncurses/./tty/hashmap.c:438:58: error: 'top' undeclared (first use in this function)
../ncurses/./tty/hashmap.c:438:72: error: 'n' undeclared (first use in this function)
make[4]: *** [../obj_s/hashmap.o] Error 1
make[4]: Leaving directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9/ncurses'
make[3]: *** [libs] Error 2
make[3]: Leaving directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9'
make[2]: *** [/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/build_dir/target-mips_uClibc-0.9.32/libncurses/ncurses-5.9/.built] Error 2
make[2]: Leaving directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32/package/ncurses'
make[1]: *** [package/ncurses/compile] Error 2
make[1]: Leaving directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-mr-mips-for-Linux-i686-gcc-4.5-linaro_uClibc-0.9.32'
make: *** [package/ncurses/compile] Error 2
I don’t understand how I can fix the problem. Are there any dependencies missing?
Only for test, I downloaded ar71xx version of SDK and I repeat the same steps for this.
URL: http://downloads.openwrt.org/attitude_adjustment/12.09/ar71xx/nand/
FILE: OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2.tar.bz2
After uncompress SDK, download the package definitions of nano and ncurses, I tried to compile with “make package/ncurses/compile V=99” and fail in other way:
leo@leo ~/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2 $ make package/ncurses/compile V=99
make[1]: Entering directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2'
make[2]: Entering directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/package/ncurses'
mkdir -p /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/dl
/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/scripts/download.pl "/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/dl" "ncurses-5.9.tar.gz" "8cb9c412e5f2d96bc6f459aa8c6282a1" "@GNU/ncurses"
--2013-10-08 11:52:44--  ftp://ftp.gnu.org/gnu/ncurses/ncurses-5.9.tar.gz
Resolving ftp.gnu.org (ftp.gnu.org)... 208.118.235.20, 2001:4830:134:3::b
Connecting to ftp.gnu.org (ftp.gnu.org)|208.118.235.20|:21... connected.
Logging in as anonymous ... Logged in!
==> SYST ... done.    ==> PWD ... done.
==> TYPE I ... done.  ==> CWD (1) /gnu/ncurses ... done.
==> SIZE ncurses-5.9.tar.gz ... 2826473
==> PASV ... done.    ==> RETR ncurses-5.9.tar.gz ... done.
Length: 2826473 (2.7M) (unauthoritative)
     0K .......... .......... .......... .......... ..........  1% 90.0K 30s
    50K .......... .......... .......... .......... ..........  3%  167K 23s
   100K .......... .......... .......... .......... ..........  5%  286K 18s
   150K .......... .......... .......... .......... ..........  7%  277K 15s
   200K .......... .......... .......... .......... ..........  9%  302K 14s
   250K .......... .......... .......... .......... .......... 10%  309K 13s
   300K .......... .......... .......... .......... .......... 12%  655K 11s
   350K .......... .......... .......... .......... .......... 14%  411K 10s
   400K .......... .......... .......... .......... .......... 16%  766K 9s
   450K .......... .......... .......... .......... .......... 18%  333K 9s
   500K .......... .......... .......... .......... .......... 19%  816K 8s
   550K .......... .......... .......... .......... .......... 21%  887K 7s
   600K .......... .......... .......... .......... .......... 23%  407K 7s
   650K .......... .......... .......... .......... .......... 25%  941K 7s
   700K .......... .......... .......... .......... .......... 27%  475K 6s
   750K .......... .......... .......... .......... .......... 28% 1.18M 6s
   800K .......... .......... .......... .......... .......... 30%  642K 6s
   850K .......... .......... .......... .......... .......... 32%  708K 5s
   900K .......... .......... .......... .......... .......... 34% 1.44M 5s
   950K .......... .......... .......... .......... .......... 36%  236K 5s
  1000K .......... .......... .......... .......... .......... 38%  140M 5s
  1050K .......... .......... .......... .......... .......... 39%  263M 4s
  1100K .......... .......... .......... .......... .......... 41%  613K 4s
  1150K .......... .......... .......... .......... .......... 43% 1.12M 4s
  1200K .......... .......... .......... .......... .......... 45%  316K 4s
  1250K .......... .......... .......... .......... .......... 47%  188K 4s
  1300K .......... .......... .......... .......... .......... 48%  292K 4s
  1350K .......... .......... .......... .......... .......... 50%  277K 4s
  1400K .......... .......... .......... .......... .......... 52%  321K 3s
  1450K .......... .......... .......... .......... .......... 54%  515K 3s
  1500K .......... .......... .......... .......... .......... 56%  560K 3s
  1550K .......... .......... .......... .......... .......... 57%  331K 3s
  1600K .......... .......... .......... .......... .......... 59%  379K 3s
  1650K .......... .......... .......... .......... .......... 61%  475K 3s
  1700K .......... .......... .......... .......... .......... 63%  552K 3s
  1750K .......... .......... .......... .......... .......... 65%  675K 2s
  1800K .......... .......... .......... .......... .......... 67%  718K 2s
  1850K .......... .......... .......... .......... .......... 68%  337K 2s
  1900K .......... .......... .......... .......... .......... 70%  826K 2s
  1950K .......... .......... .......... .......... .......... 72% 1004K 2s
  2000K .......... .......... .......... .......... .......... 74%  681K 2s
  2050K .......... .......... .......... .......... .......... 76%  481K 2s
  2100K .......... .......... .......... .......... .......... 77%  660K 1s
  2150K .......... .......... .......... .......... .......... 79%  573K 1s
  2200K .......... .......... .......... .......... .......... 81% 1.67M 1s
  2250K .......... .......... .......... .......... .......... 83%  487K 1s
  2300K .......... .......... .......... .......... .......... 85%  660K 1s
  2350K .......... .......... .......... .......... .......... 86%  912K 1s
  2400K .......... .......... .......... .......... .......... 88%  737K 1s
  2450K .......... .......... .......... .......... .......... 90%  608K 1s
  2500K .......... .......... .......... .......... .......... 92%  685K 0s
  2550K .......... .......... .......... .......... .......... 94%  543K 0s
  2600K .......... .......... .......... .......... .......... 96%  960K 0s
  2650K .......... .......... .......... .......... .......... 97%  677K 0s
  2700K .......... .......... .......... .......... .......... 99% 1.09M 0s
  2750K ..........                                            100% 2.80M=6.0s
2013-10-08 11:52:53 (460 KB/s) - written to stdout [2826473]
. /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/include/shell.sh; gzip -dc /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/dl/ncurses-5.9.tar.gz | /bin/tar -C /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/.. -xf -
Applying ./patches/100-ncurses-5.6-20080112-urxvt.patch using plaintext:
patching file misc/terminfo.src
Applying ./patches/101-ncurses-5.6-20080628-kbs.patch using plaintext:
Applying ./patches/200-fix_missing_include.patch using plaintext:
patching file ncurses/curses.priv.h
Hunk #1 succeeded at 55 (offset 1 line).
Applying ./patches/500-cross.patch using plaintext:
patching file aclocal.m4
Hunk #1 succeeded at 5137 with fuzz 2 (offset 839 lines).
Applying ./patches/900-terminfo.patch using plaintext:
Hunk #1 succeeded at 3947 (offset 240 lines).
touch /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/.prepared_3ff29d8390877387f3ae465f1d81f5e4
(cd /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/./; if [ -x ./configure ]; then /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/host/bin/find /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/ -name config.guess | xargs -r chmod u+w; /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/host/bin/find /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/ -name config.guess | xargs -r -n1 cp /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/scripts/config.guess; /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/host/bin/find /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/ -name config.sub | xargs -r chmod u+w; /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/host/bin/find /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/ -name config.sub | xargs -r -n1 cp /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/scripts/config.sub; AR=mips-openwrt-linux-uclibc-ar AS="ccache_cc -c -Os -pipe -mips32r2 -mtune=mips32r2 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -fpic" LD=mips-openwrt-linux-uclibc-ld NM=mips-openwrt-linux-uclibc-nm CC="ccache_cc" GCC="ccache_cc" CXX="ccache_cxx" RANLIB=mips-openwrt-linux-uclibc-ranlib STRIP=mips-openwrt-linux-uclibc-strip OBJCOPY=mips-openwrt-linux-uclibc-objcopy OBJDUMP=mips-openwrt-linux-uclibc-objdump SIZE=mips-openwrt-linux-uclibc-size CFLAGS="-Os -pipe -mips32r2 -mtune=mips32r2 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -fpic " CXXFLAGS="-Os -pipe -mips32r2 -mtune=mips32r2 -fno-caller-saves -fhonour-copts -Wno-error=unused-but-set-variable -msoft-float -fpic " CPPFLAGS="-I/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/target-mips_r2_uClibc-0.9.33.2/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/target-mips_r2_uClibc-0.9.33.2/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/toolchain-mips_r2_gcc-4.6-linaro_uClibc-0.9.33.2/usr/include -I/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/toolchain-mips_r2_gcc-4.6-linaro_uClibc-0.9.33.2/include " LDFLAGS="-L/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/target-mips_r2_uClibc-0.9.33.2/usr/lib -L/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/target-mips_r2_uClibc-0.9.33.2/lib -L/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/toolchain-mips_r2_gcc-4.6-linaro_uClibc-0.9.33.2/usr/lib -L/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/staging_dir/toolchain-mips_r2_gcc-4.6-linaro_uClibc-0.9.33.2/lib "   ./configure --target=mips-openwrt-linux --host=mips-openwrt-linux --build=x86_64-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib --sysconfdir=/etc --datadir=/usr/share --localstatedir=/var --mandir=/usr/man --infodir=/usr/info --disable-nls   --enable-echo --enable-const --enable-overwrite --disable-rpath --without-ada --without-debug --without-profile --without-progs --disable-big-core --disable-home-terminfo --with-normal --with-shared --with-terminfo-dirs=/usr/share/terminfo --with-default-terminfo-dir=/usr/share/terminfo ; fi; )
configure: loading site script /home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/include/site/mips-openwrt-linux-uclibc
checking for egrep... grep -E
Configuring NCURSES 5.9 ABI 5 (Tue Oct  8 11:52:54 ART 2013)
checking build system type... x86_64-pc-linux-gnu
checking host system type... mips-openwrt-linux-gnu
checking target system type... mips-openwrt-linux-gnu
Configuring for linux-gnu
checking for prefix... /usr
checking for mips-openwrt-linux-gcc... ccache_cc
checking for C compiler default output... configure: error: C compiler cannot create executables
make[2]: *** [/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/build_dir/target-mips_r2_uClibc-0.9.33.2/libncurses/ncurses-5.9/.configured_] Error 77
make[2]: Leaving directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2/package/ncurses'
make[1]: Leaving directory `/home/leo/Documentos/openwrt/OpenWrt-SDK-ar71xx-for-linux-i486-gcc-4.6-linaro_uClibc-0.9.33.2'
I’m running Linux Mint 15 64 bits.
Am I doing something wrong?
Any help will be appreciated.
bump!
Could somebody give me a clue about this?
I have a working PCI passthru under Xen with Debian6 (squeeze), Xen4.0, HP DL380G6 onboard Broadcom 2xDualport
since the mobo has two dualport NICs integrated, i can’t passthru only one port, it’s a must to use the whole second card.
(since DL380g8 has a quad port NIC integrated, i can use only the whole NIC for virtualisation purposes, that’s why i added a second -dualport- server NIC)
the server is facing to a RB1100AH. If i make a btest from RB1100AH to the virtualised RouterOS, it can make
TCP: RB1100<-PC 240mbps
RB1100->PC 900mbps
if i raise the MTU to 9000bytes
240mbps increases to 290mbps
and 900mbps increases to 980mbps
UDP both: 900mbps/970mbps
it seems to me, there is a bottleneck (in interface queueing?) somewhere.
Because the NIC fully passed to Guest OS, i have no control over it at all in virtualisation enviroment (like disabling TCP offload, etc)
ps: the tests above made with ROS5.18. I’ve upgraded to 6.7 and i’ve lost an interface - what’s still visible in the PCI list! thruput not raised, CPU usage not decreased.
edit: it seems, the RB1100AH cannot deal with btest-receiving more than 250mbps. if i replace the RB1100AH with a HP Microserver (with ROSx86) the NIC with PCI-passthru
can do 950mbps in any direction or 940/730 in both directions. (tcp)
