Problem buying a copy CHR
Hi
When you pay to buy a copy CHR show me the following problem
"You have started authorization procedure!
Please check your creditcard statement and read last transaction made by www.mikrotik.com. Write down Exact Amount of the Charge in USD.
Expected format for currency input is 1.xx.
If your creditcard statement shows status in other currency than USD and you cannot see the original deduced amount, please convert it using latest exchange rate!
You have already used all attempts to authorize with charged amount!
Enter Transaction Authorization Code (5-6 symbols):
what do you mean
You don’t buy CHR. You can buy a CHR license though, is that what you mean?
