Problem changing the managment VLAN
Hello, I am new user whit the mikrotik switches. Its a a nice device, but I have some troubles to configure the managment vlan. I hope someone can me give some input.
I have a verry simple szenario:
Hardware: 8 Port CSR210 Switch:
  1. Port 1 is mi uplink port to a firewall. The port on the firewall is tagged whit vlan 34 and vlan 35
  2. I want to make port 2 to 6 untagged VLAN34
  3. I want to make port 7 and 8 unttaged VLAN35
  4. I need to change the management IP from default 192.168.88.1/24 to 192.168.34.254/24
  5. The management ip must be reacable from the port 2 to 6 (untagged VLAN34) and from the firewall
This is are my steps: the vlans are working. the only problem ist the management IP and VLAN ( Step 4 and 5)
set ether2 master-port=ether1
set ether3 master-port=ether1
set ether4 master-port=ether1
set ether5 master-port=ether1
set ether6 master-port=ether1
set ether7 master-port=ether1
set ether8 master-port=ether1
add name=bridge1 protocol-mode=none
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
/interface ethernet switch ingress-vlan-translation
add ports=ether2 customer-vid=0 new-customer-vid=34 sa-learning=yes
add ports=ether3 customer-vid=0 new-customer-vid=34 sa-learning=yes
add ports=ether4 customer-vid=0 new-customer-vid=34 sa-learning=yes
add ports=ether5 customer-vid=0 new-customer-vid=34 sa-learning=yes
add ports=ether6 customer-vid=0 new-customer-vid=35 sa-learning=yes
add ports=ether7 customer-vid=0 new-customer-vid=35 sa-learning=yes
add ports=ether8 customer-vid=0 new-customer-vid=35 sa-learning=yes
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1 vlan-id=34
add tagged-ports=ether1 vlan-id=35
add ports=ether1,ether2,ether3,ether4,ether5,ether6 vlan-id=34 learn=yes
add ports=ether1,ether7,ether8 vlan-id=35 learn=yes
I hope someone can help me.
This is wrong:
It should be 34 not 35.
On this you need to add switch1-cpu:
add ports=switch1-cpu,ether1,ether2,ether3,ether4,ether5,ether6 vlan-id=34 learn=yes
Add a VLAN interface:
/interface vlan
add interface=ether1 name=vlan34 vlan-id=34
and put an IP address on it:
add address=192.168.34.254/24 interface=vlan34
You probably want to set vlan-mode=secure as well on “/interface ethernet switch vlan” once you’re all setup, tested and working (use Safe mode just in case you cut yourself off).
Hello thanks for the fast reply. But no chance to whit this config i have the same problem. The switch is not accessible on the untagges vlan 34 and not accessible from the firewall.
here is a export of my config:
[admin@MikroTik] > export
jan/02/1970 00:09:33 by RouterOS 6.28
software id = T11H-PR7D
set [ find default-name=ether1 ] name=ether1-master-local
set [ find default-name=ether2 ] master-port=ether1-master-local name=ether2-slave-local
set [ find default-name=ether3 ] master-port=ether1-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-master-local name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-master-local name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-master-local name=ether8-slave-local
set [ find default-name=sfp-sfpplus1 ] master-port=ether1-master-local name=sfp-sfpplus1-slave-local
set [ find default-name=sfpplus2 ] master-port=ether1-master-local name=sfpplus2-slave-local
/interface vlan
add interface=ether1-master-local l2mtu=1584 name=vlan34 vlan-id=34
/port
set 0 name=serial0
add bridge=bridge1 interface=ether1-master-local
add tagged-ports=ether1-master-local vlan-id=34
add tagged-ports=ether1-master-local vlan-id=35
add customer-vid=0 new-customer-vid=34 ports=ether2-slave-local sa-learning=yes
add customer-vid=0 new-customer-vid=34 ports=ether3-slave-local sa-learning=yes
add customer-vid=0 new-customer-vid=34 ports=ether4-slave-local sa-learning=yes
add customer-vid=0 new-customer-vid=34 ports=ether5-slave-local sa-learning=yes
add customer-vid=0 new-customer-vid=35 ports=ether6-slave-local sa-learning=yes
add customer-vid=0 new-customer-vid=35 ports=ether7-slave-local sa-learning=yes
add customer-vid=0 new-customer-vid=35 ports=ether8-slave-local sa-learning=yes
add ports=ether1-master-local,ether2-slave-local,ether3-slave-local,ether4-slave-local,ether5-slave-local vlan-id=34
add ports=ether1-master-local,ether6-slave-local,ether7-slave-local,ether8-slave-local vlan-id=35
add address=192.168.88.1/24 comment="default configuration" interface=ether1-master-local network=192.168.88.0
add address=192.168.34.254/24 interface=vlan34 network=192.168.34.0
/romon port
add disabled=no
/system routerboard settings
set protected-routerboot=disabled
As mentioned above, you need to add switch1-cpu to the vlan definition and egress tag lines for each vlan that needs a routed interface.
This line:
/interface vlan
adds a vlan interface for Routeros, but the switch can only interface to Routeros if switch1-cpu is added to switch vlan and egress-vlan-tag as below:
add ports=ether1-master-local,ether2-slave-local,ether3-slave-local,ether4-slave-local,ether5-slave-local,switch1-cpu vlan-id=34
add tagged-ports=ether1-master-local,switch1-cpu vlan-id=34
Also, delete the bridge and bridge port. You don’t want to put ether1 on a bridge by itself; you have a vlan attached to it.
This was exact the solution. Thank you verry much. No it works
add ports=ether6 customer-vid=0 new-customer-vid=34 sa-learning=yes
/interface vlan
