I am trying to connect Mikrotik with wireless AP according to https://wiki.mikrotik.com/wiki/Manual:Wireless_AP_Client.
On my AP I set the test wifi network without any security / passwords. I can not connect. Mikrotik does not try to connect at all.
MIkrotik hAPac2
Firmware 6.42.1
Interface
Mode: station
Band: 2.4GHz
Frequency: 2412
SSID: “My network SSID”
Hello, have you set up your AP correctly?
Yes. I used a TP-Link router for testing on which the wifi network has no security. I can connect to this AP with my phone or computer without any problem.
make sure frequency is correct (if you do a scan from Mikrotik and then select connect, it will pick up the correct frequency for you)
Problem solved. During configuration I changed the mac address for MIkrotik wlan1 and this caused the problem. I entered it at the very beginning of the configuration and later forgot to change it.
I can use the changed mac from the mac generator (https://www.miniwebtool.com/mac-address-generator/) if the address prefix is the same as the real one. If it is different, it does not work.
The problem was my fault.
Thank you all for your help.
