Problem connecting to hidden SSID CAPsMAN
Greetings!
The following problem (on firmware 7.11.2 and 6.49.15)
CAPsMAN broadcasts 2.4 onlyN and 5 onlyAC (RB2011 (and GROOVE was on the test))
There are devices (Huawei Y3 2017 and other smartphones) that connect to non-hidden networks in this mode, but not to hidden ones.
If you set onlyGN (BG) in the hidden network settings, the device connects.
On a smartphone it looks like this:
In the Wi-Fi settings, set the network - SSID, WPA2, password, hidden network
If onlyN then the network falls into the list of saved networks and that’s it - there is no connection.
If we change it to something other than onlyN, then the network immediately appears in the search and connects.
CAPsMAN on VLAN. On the forum, for firmware 7.12 and higher, I found the following:
VLAN ID - 802.11n/ac interfaces do not support this type of VLAN tagging in the wifiwave2 package, but they can be configured as VLAN access ports in the bridge settings.
But my firmware is older and the wifiwave2 package is not supported.
What is the reason for this behavior?
