Problem connecting to RB953GS
Hi
I am trying to “resurrect” a relatively (I’d say a 3-4 years) old RouterBoard RB953GS.
For some reason I can’t seem to be able to connect - after boot it comes up like this in Winbox
but can’t seem to actually connect. After a few minutes it altogether disappears.
I tried a reset (not exactly sure about the procedure but I think I have to short the small hole near the USB ?) to no avail.
Any suggestion most welcome !
There’s some info about resetting in quick guide in the download section of product page.
ROS version on the device is pretty old and I guess that winbox 3.21 is simply too new for it. I’d try to upgrade ROS to some recent version using netinstall. And connection to console using RS-232 port my be your friend as well …
I might be a bit thick but I don’t seem to find the note you are mentioning…
It’s in Quick Guide, section Buttons.
i think that the winbox version is to new. Try an older one
Thanks - it was indeed an issue with the Winbox version. 3.18 allowed me in - updated - all ok !
