I want to use a dns over https by mullvad
https://certs.godaddy.com/repository
GoDaddy Class 2 Certification Authority Root Certificate - G2
config a mikrotik:
/tool fetch url=https://certs.godaddy.com/repository/gdroot-g2.crt
/certificate import file-name=gdroot-g2.crt passphrase=“”
/ip dns set use-doh-server=https://doh.mullvad.net/dns-query verify-doh-cert=yes
/ip dns/ cache/ flush
doesn’t work
please help me
[SOLVED]
Do not work, use only TLS 1.2 / TLS 1.3 with unsupported elliptic ciphers from MikroTik products.
Only
TLS 1.3
TLS_AES_256_GCM_SHA384
TLS_CHACHA20_POLY1305_SHA256
TLS_AES_128_GCM_SHA256
and
TLS 1.2
TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
[rex@net] >tool fetch url=“https://doh.mullvad.net/dns-query”
status: failed
failure: ssl connection error: internal error (6)
No, is simply unsupported
its RouterOS7 unsupported?
I must rewrite the reply on post #2 ???
ok. thank you.
unsupported elliptic ciphers from MikroTik products - problem in ROS.
Was considering switching from Cloudflare to Mullvad but saw this. Is it still unsupported?
Use
/tool fetch url=https://curl.se/ca/cacert.pem
/certificate import file-name=cacert.pem passphrase=“”
