Problem downgrading RoS to 6.44.2
Hi all,
anyone else has problem downgrading to 6.44.2? (anyone tried?).
I`ve downloaded “all_packages-mipsbe-6.44.2.zip” from official web site and hit /system package downgrade
and still nothing. ROS stays same (current is 6.59.9).
Now, as far as I know, RoS is not suppose to go under the value under “Factory Firmware”, right?
Ive done this befor,e as I did had many of Tiks around that I have managed to successfully downgrade.
Any suggestions?
thank you.
Did you try netinstall?
Why this old version?
Netinstall is not an option; reason if that Tik is located on the other side of the world (mainly, UK, this one).
So it has a specific type of build that requires an VPN connection in order to work in a way I want it to. It`s an production Tik.
Old version because of bogus login via api port (newer builds require change on my server side in order to succeed in login in to Tik and changing “stuffies” such as Hotspot name, bandwith limits and monitoring). So its my plan to keep it like this until we rearrange things required in order for newer Tiks to work. Short-time solution only.
Instead all packages zip, simply use NPK file and downgrade it.
Regards.
