Problem DUAL WAN Load Balancing using PCC with EOIP-Tunnel
Dear Support I have a problem with a configuration which I detail below:
I have a mikrotik RB1100 ahx2 team with two internet connections using a setup DUAL WAN Load Balancing using PCC method which functions normally. After that I require to configure a tunnel EoIP-Connection to remotely access one of our application servers. This is where the problem is gender, the connection is established without any problem but if I active the dual wan load balancing using PCC does not allow me to access the server, even I can not come up with the (ping) command. The server is in my local network only active if one of the connections can be accessed.
Note that when the dual Wan activates and configures the tunnel can EoIP-only access to the local interface of the Mikrotik.
I wonder if you will be missing some additional rule in the mangle to allow the connection from reaching EoIP-tunnel
