hello
i have mikrotik 5.20 and i install on pc its work good and when i try login to 192.168.1.1 frist time its login normal but after some days i try login and can’t login and say this massage
ERROR: Gateway Timeout
While trying to retrieve the URL > http://192.168.1.1/ > :
Connection timed out
Your cache administrator is webmaster.
Generated Thu, 10 Mar 2016 01:13:36 GMT by 192.168.1.1 (Mikrotik HttpProxy)
and when i ping too i get request time out
any idea to fix this problem
try winbox how ?
i need login to my router adsl not mikrotik
It seems you have enabled web cache server , so exclude your ADSL modem’s IP address from cache in mikrotik
i already enable proxy and exlude ip address router to and still not login
it’s better to send your router configuration here , specially firewall and proxy settings
ok No problem but sorry about that how i can configuration this firewall and proxy
use terminal and print ?
this firewall
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
"place hotspot rules here" disabled=no to-addresses=0.0.0.0
add action=masquerade chain=srcnat disabled=no out-interface=ether1
add action=masquerade chain=srcnat disabled=no src-address=10.0.0.0/24
add action=redirect chain=dstnat disabled=no dst-port=80 protocol=tcp \
to-ports=8080
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=yes src-address=10.0.0.0/24 to-addresses=0.0.0.0
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
and this proxy
enabled: yes
src-address: 192.168.1.1
port: 8080
parent-proxy: 0.0.0.0
parent-proxy-port: 0
cache-administrator: webmaster
max-cache-size: none
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: yes
always-from-cache: no
cache-hit-dscp: 4
cache-drive: primary-slave
Your ADSL ip is 192.168.1.1 and then you’ve set your web proxy src-address to 192.168.1.1 !!
disable your entire web proxy and check if your ADSL modem is reachable
also let web-proxy src-address to be blank , router will use the best in its routing table
http://wiki.mikrotik.com/wiki/Manual:IP/Proxy
ShayanFiroozi:
ok i do to that and still can’t login adsl modem
and before time i set this configuration and work good and i take backup and restore and work good but after 4 or some hours i get this problem
disable this and test again :
to-ports=8080
it’s better to send your full configuration and tell us how your ADSL model connected to your router and with which interface
to-ports=8080
i disable this rule and test but still not work and how i can get full configuration ??
my ADSL modem connected by pppoe to my router
run export hide-sensitive in terminal
ok i will do it but if i need set new configuration u can tell me correct option ? or link can i learn from here ?
need to know what you gonna do ?
draw your network diagram visually with some software like visio and post it here
ok i need make new set for my mikrotik all configruation
i need configruation my mikrotik simple configruation trafic log in from router to mikriotik to network
i work by hostspot
so i need correct setting to hotspot /routers /firewwall / DCHP client / web proxy / address
