good morning,
I updated the RB to both version 6.44.5 and 6.45.6 but I no longer connect to the vpn client pptp even l2tp
can you help me?
thanks
good morning,
can you help me?
thanks
You should provide more information about your environment, both client and server.
What saying RB log?
attach log
thanks
Check on your RB server allowed encryption types and then on your client side that that might be issue.
What is saying your client logs?
Also post here your RB config parts.
/interface pptp-server export hide-sensitive
/interface pptp-client export hide-sensitive
/ppp secret export hide-sensitive
/ppp profile export hide-sensitive
I had used their guide
https://support.hidemyass.com/hc/en-us/articles/204558497-Mikrotik-Client-Setup
So, then you should check configuration of your RB under these options, look below.
/ppp secret
/ppp profile
I checked
i also have ipvanish as vpn and that goes
If you want solve this issue, you need post here 2 things:
add connect-to=xxx disabled=no name=hma password=xxx user=xxx
