Hi
I have a Mikrotik setup to use IP addresses provided by my DSL ISP.
The Ip’s are passed through a Cisco 837 router and have a /29 netmask.
The Ip’s i think are passed via a VPN tunnel from the ISP.
The IP’s are Static and thus provided over the VPN.
I have a problem thus
I have assign x.x.x.130 to the mikrotik
The Cisco is x.x.x.129
The netblock is x.x.x.128/29 thus x.x.x.128 - x.x.x.135
The IP address i have bound onto a server is x.x.x.131. It also has another live IP of y.y.y.220.
I have added a static route for x.x.x.131/32 to point to the server on y.y.y.220.
This is the problem … the mikrotik has an address y.y.y.221
I can not allow traffic on the y.y.y.216/29 network to not flow
When i set the server’s default gateway to the mikrotik and not to the y.y.y.217 I can ping the server but not ssh or telnet to ports 25 110 3389 and 80
Any idea’s - when it runs with the other network of y.y.y.217 as the default gateway thus bypassing the mikrotik everything works.
When i set the Mikrotik as default everything dies..
Any ideas…
Regards
Malcolm
