Problem importing backup from 4.0 Beta 3
Hi, I’m trying to import from our old dude server, that is monitoring about a 1000 hosts with various services, the problem is we use some agents spreaded across our network, and as Dude V6 doesn’t support agents anymore, the hosts that are using other agent then the default one are being imported misconfigured.
Also are being “created” a lot more agents, with names of various existing hosts on the old configuration.
Dude v6 support agents: https://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Agents, and they should be on ROS only.
My install don't have those menus, i'm running V6.40, that was removed from Dude? See the screenshots.
Exit from command:
[admin@MikroTik] > dude agent
add comment edit find print remove set
[admin@MikroTik] > dude agent print
NAME
[admin@MikroTik] >
rodriguescr,
If I understand correctly, agent should be specified as a regular device. What do you see under your devices Settings?
With version 6.37.5 i was able to get the Agents menu back and fix all hosts that had different agents other then default.
Now i think i just have a sort of a BUG after updating to V6.38+, all hosts with the checkbox Router OS checked, are appearing as a possible agent in the list instead of just the ones with the Dude Server marked. But i think that’s fine for now, we can use the software the way it is.
