Hello everyone
I have problem in firewall that change automatic sequence don’t anyone change rules but it is changed automatically, what is the problem and how can i stopped the automatic change.
Note i watch by “log” but not one change it.
Regards
hello
i think you should reset configuration and then re-config your router
The problem was solved
