Problem in forwarding port80 when mangle rule is enabled
hi,
newbie here, needing your help.
my port80 forwarding(hair pin code) does not function when mangle rule load balancing(urdu guide) is enable.
thanks in advance for your prompt attention.
You forgot to attach your code. I don’t think anybody here is psychic, so you’re probably not going to get any help unless you can post details of your configuration!
