Problem in limiting connections PPPoE
Hi, when I limit it like 51200 bytes, in user configs. It disconnects 2-3 seconds later it connected.
I want my customers to get 512 kilobit/sc download and 128kbit/sc upload.
what kind of queues do you use?..
Everything’s default. I only did:
http://imagewaiter.com/view-151_profilepppoeinmikro.JPG
that in winbox.
it’s amount of traffic. you can set bandwidth limits in user’s profile in Profiles tab
it limits tx and rx rate same.
How can I let a customer to use 128 kbps upload and 512 kbps download?
RTFM carefully?..
Rate-Limit - Datarate limitation for DHCP clients. Format is: rx-rate[/tx-rate] [rx-burst-rate[/tx-burst-rate] [rx-burst-threshold[/tx-burst-threshold] [rx-burst-time[/tx-burst-time][priority] [rx-rate-min[/tx-rate-min]]]]. All rates should be numbers with optional ‘k’ (1,000s) or ‘M’ (1,000,000s). If tx-rate is not specified, rx-rate is as tx-rate too. Same goes for tx-burst-rate and tx-burst-threshold and tx-burst-time. If both rx-burst-threshold and tx-burst-threshold are not specified (but burst-rate is specified), rx-rate and tx-rate are used as burst thresholds. If both rx-burst-time and tx-burst-time are not specified, 1s is used as default. Priority takes values 1..8, where 1 implies the highest priority, but 8 - the lowest. If rx-rate-min and tx-rate-min are not specified rx-rate and tx-rate values are used. The rx-rate-min and tx-rate-min values can not exceed rx-rate and tx-rate values.
128000/512000
used like that it works now.
512000/128000 !!!
and then users should reconnect
I tried
512000/128000
in the beginning. But speed was so low like download speed is around 60-70kbps
than I tried other one with [
but these values are client sided. So that should be reversed.
Thanx for everything.
How can I use quota on their system?
I see now, the thing in secrets part which is
Limit Bytes Out is download quota
Limit Bytes In is upload quota
But when quota is finished, connection goes out. After that, user can connect!!! I don’t want customer to connect again. And customer or I can see his quota status. How can I do that?
