I’m using RB450g, RouterOS 5.12. I’m configure my mikrotik as a DHCP server but problem is the leased IP being change several times for several workstation. This incident happened 4-5 times so far. As a result the queue already I’m created is not running practically. I’m re-configure this DHCP 2-3 times but same result found. But if I use a normal broadband router then all is perfectly OK.
I can’t understand where the problem is? Is there a bug in RouterOS? any help/suggestion is appreciate.
also try to use a lease time big enough (routeros default is 3 days and it’s working good for me) and a good ups.
before 5.22 there was a problem with dynamic assigned ip’s that if the router lost power the dhcp server would loose the dynamic assignments and the ip’s would change, sometimes even assign one ip to two clients.
