hi
i have a problem in 411 bord that when i put a mini pci to make it ap brigh . it been so hot and not work any more
by the way i use antena gain 5mhz 20 dbi
wht i do ? and how fix this problem ??
what miniPCI card you plug in? is it known good card? have you tried to use another card in the board?
From minimal description you gave it seems that your miniPCI module might be damaged or your PSU does not not supply enough power. Also, there might be some other issue we are not yet aware of.
there is no name on the pci `s just i know the power of it
350 wat and 630 wat
i use 350 for 411 i ge the problem
Mikrotik Router OS v5.20 is only supporting in a server class motherboard with 2 PCI slots , any version available with support for both PCI & PCIx
[admin@xxx] /system> license print
software-id: xxxx-xxxx
upgradable-to: v7.x
nlevel: 5
features:
You board only support MiniPCI Type IIIB standard cards, please review http://i.mt.lv/routerboard/files/rb411ugA.pdf
