totti
May 24, 2011, 5:31pm
1
I’m trying to make profiles work i make the limit rate 128k/128k so i should download with 15-20kb/s but that’s not ..also queues not showing any traffics or statics I’m using 3.30
here’s a photo to explain my problem
I’ve tried to reinstall mikrotik from 0 but still have the same problem
sorry for my bad English cause it’s not my main language.
That “target-address” should be a localnet ip. Is 9.9.9.0/24 assigned to your hotspot localnet?
Check “/ip hotspot host”. The “to-address” is the one your queue sees. If you do not understand it, please post it here.
totti
May 24, 2011, 6:31pm
3
How do i check that?
I type /ip hotspot host and its appers like
[admin@MikroTik] > /ip hotspot host
[admin@MikroTik] /ip hotspot host>
nothing else
I am sorry. I forgot that. This will show you what ip is being used by each user.
/ip hotspot active
print
ADD: If you have no entries in the “/ip hotspot host”, then nobody is on the hotspot interface.
What interface is that computer downloading connected to?
totti
May 24, 2011, 6:35pm
5
Flags: R - radius, B - blocked
USER ADDRESS UPTIME SESSION-TIME-LEFT IDLE-TIMEOUT
0 admin 9.9.9.2 1h13m47s
1 nasasat 9.9.9.7 1h10m54s
Those are not private ips.
What interface is the hotspot assigned to?
What interface is your WAN (internet) connection on?
totti
May 24, 2011, 6:40pm
7
Hotspot assigned to lan"9.9.9.9"
Wan"192.168.1.2"
I hope that’s what you mean
I don’t understand. Please post “/ip address print”.
totti
May 24, 2011, 6:51pm
9
[admin@MikroTik] > /ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.1.2/24 192.168.1.0 192.168.1.255 wan
1 9.9.9.9/24 9.9.9.9 9.9.9.9 lan
[admin@MikroTik] >
also
[admin@MikroTik] /ip hotspot host> print
Flags: S - static, H - DHCP, D - dynamic, A - authorized, P - bypassed
# MAC-ADDRESS ADDRESS TO-ADDRESS SERVER IDLE-TIMEOUT
0 HA 44:87:FC:8E:7E:04 9.9.9.2 9.9.9.2 hotspot1
1 HA 00:11:5B:E8:F6:23 9.9.9.7 9.9.9.7 hotspot1
2 D 00:16:17:7A:A7:7E 192.168.1.71 9.9.9.3 hotspot1 5m
Try this:
set 1 network=9.9.9.0
set 1 broadcast=9.9.9.255
Those previous settings are the wrong settings for a /24 subnet. I do not know what else that will affect.
Please post “/ip hotspot” and “/ip hotspot profile”.
totti
May 24, 2011, 7:03pm
11
[admin@MikroTik] /ip hotspot profile> print
Flags: * - default
0 * name="default" hotspot-address=0.0.0.0 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=http-chap split-user-domain=no use-radius=no
1 name="hsprof1" hotspot-address=9.9.9.9 dns-name="" html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
[admin@MikroTik] > /ip hotspot print
Flags: X - disabled, I - invalid, S - HTTPS
# NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
0 hotspot1 lan hs-pool-1 hsprof1 5m
[admin@MikroTik] >
ٍstill the same problem btw
totti
May 24, 2011, 11:09pm
12
Well that’s how i setup My Mikrotik I added Ip address for wan/lan and added the routes and dns then setup hotspot that’s all or there’s something i need to do also for queues?
totti
May 29, 2011, 5:28pm
13
Please still need some help here…
fewi
May 29, 2011, 8:05pm
14
Just to get all the information into one post in a readable format, please post the output of “/ip address print detail”, “/ip route print detail”, “/interface print”, “/ip firewall export”, “/queue export”, “/ip hotspot export”, and an accurate network diagram.
Are you using bridges? Is your HotSpot running in a bridged interface? If so, try setting /interface bridge settings set use-ip-firewall=yes
Regards
totti
May 29, 2011, 10:45pm
16
[admin@MikroTik] > /ip address print detail
0 address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 interface=wan
actual-interface=wan
1 address=9.9.9.1/24 network=9.9.9.0 broadcast=9.9.9.255 interface=lan
actual-interface=lan
2 D address=192.168.1.100/24 network=192.168.1.0 broadcast=192.168.1.255 interface=wan
[admin@MikroTik] > /ip route print detail
0 S dst-address=0.0.0.0/0 gateway=192.168.1.1 interface=wan gateway-state=reachable
distance=1 scope=30 target-scope=10
1 ADS dst-address=0.0.0.0/0 gateway=192.168.1.1 interface=wan gateway-state=reachable
distance=0 scope=30 target-scope=10
2 ADC dst-address=9.9.9.0/24 pref-src=9.9.9.1 interface=lan distance=0 scope=10
3 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.2 interface=wan distance=0 scope=10
/interface print
[admin@MikroTik] > /interface print
# NAME TYPE MTU L2MTU
0 R lan ether 1500
1 R wan ether 1500
/ip firewall export
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=accept chain=forward comment=allow connection-state=established \
disabled=no
add action=add-dst-to-address-list address-list=User-Download-list \
address-list-timeout=1h chain=forward comment="exe fils" content=.exe \
disabled=no protocol=tcp
address-list-timeout=1h chain=forward comment=rar content=.rar disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=7z content=.7z disabled=no \
protocol=tcp
address-list-timeout=1h chain=forward comment=rmvb content=.rmvb \
address-list-timeout=1h chain=forward comment=zip content=.zip disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=bin content=.bin disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=ram content=.ram disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=asf content=.asf disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=mov content=.mov disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=wmv content=.wmv disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=mpg content=.mpg disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=mpeg content=.mpeg \
address-list-timeout=1h chain=forward comment=mkv content=.mkv disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=avi content=.avi disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=flv content=.flv disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=pdf content=.pdf disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=iso content=.iso disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=nrg content=.nrg disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=wav content=.wav disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=rm content=.rm disabled=no \
protocol=tcp
address-list-timeout=1h chain=forward comment=mp3 content=.mp3 disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=mp4 content=.mp4 disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=wma content=.wma disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=dat content=.dat disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=vcd content=.vcd disabled=\
no protocol=tcp
address-list-timeout=1h chain=forward comment=cab content=.cab disabled=\
no protocol=tcp
/ip firewall mangle
add action=mark-packet chain=forward comment="" disabled=no new-packet-mark=\
User-Download-Fils passthrough=no protocol=tcp src-address-list=\
User-Download-list src-port=80
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=no src-address=9.9.9.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
totti
May 29, 2011, 10:47pm
17
What do you mean with bridges?
totti
June 9, 2011, 11:02am
18
actually still need help here a lot )=
fewi
June 9, 2011, 1:20pm
19
You didn’t post the most important part, “/ip hotspot export”.
