hi i have a problem
i install the os 3.2 on a X86 pc duel core 2 , 512 MB RAM , mother board inTEL D101GGC,HDD SATA 250 GB.
AFTER INSTALING THE OS 3.2 IT WORKS fine ..but after shutdown the ROuter and start runing again it not work “Loading system”…
i guest that when i but the network card " realtik RTL8139D" AFTER configuring the network card …i have other problem
" Intel UMDNI , PXE-2.1 (build 082)
Copyright(c) 1997-2000 Intel corporation
For Realtek RTL8139(X)/8130/810x PCI Fast Ethernet controller v2.3 (021015)
CLIENT MAC ADDR: 00 E0 1C 3B 6D 95 "
AFTER THAT nothin happen!!! any one help plzzzz
now i wel format the hard and put XP sp2 and after that i well reinstal the OS 3.2 ..i hope it work…
((( i m using a os 2.9 ))) righti now other than the OS V3.2 ..there is any problem if i link the 2 router at the same time !? cz i cant turn of the fisrt router..i have to configure the os 3.2 to take a place of the first on OS 2.9 ..any help!>
if you format your HD with windows, you will lose your license
sounds simple enogh.
- Your NIC is trying to boot. Change your boot priority to whatever drive you have your system on.
- install windows? WTF! Got me on that one, but simply put, do a net install or connect a USB CD DRIVE and install from ISO, don’t need windows!
System is trying to LAN boot, just change boot order from bios and it should work.
To make sure it is a NIC (LAN Interface/Network Card) problem, just remove the card and check what is going on !
tx all ![]()
but i do some think batter looooooooool
i bot a new computer and instal the OS 3.2
and every think is ok thank you all
and yes it was form the lan card
but even when i revovet for the pc it stell the same ![]()
“not easily”, I can understand your that problem has been solved ! Thanks God ![]()
