I have the following Problem:
I used the following HowTo (http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks) with two RB433AH. I tried it several times with this HowTo on different Routers (all RB433AH). Sometimes the WDS Link is createt and sometimes it is not. I have reset the systemconfiguration and I did every time the same to set up the WDS according to the HowTo.
Has anyone experienced the same problems or does anybody has a hint for me? If you need any more information just tell me…
thx in advance
greetings Pagani
