Problem LVL5 and only 200 PPtP dynamic tunnels.
I have Mikrotik lvl5 on flashIDE 512MB, but there are strange things, in ppp 220 users from which 20 radius appoint statics real address, and 200 with the dynamic address. 201 user with the dynamic address tries to be connected - the radius send framed-ip 10.х.х.х, and in ppp it does not appear and accordingly error 738 (the server has not appointed the address). If at the user with static address that it connected is normal. What can it be?
PS. At first there was level licence 4, have then updated it to 5 levels - simply having updated a key.
what’s in Log of RouterOS?
It is a maximum that I have achieved from logs of ros:
Sep/17/2009 18:22:46 pptp,ppp,info : waiting for call…
Sep/17/2009 18:22:47 pptp,ppp,info : authenticated
Sep/17/2009 18:22:47 pptp,ppp,info : using encoding - MPPE128 stateless
Sep/17/2009 18:22:47 route,event,debug Interface change
Sep/17/2009 18:22:47 route,event,debug id=146160
Sep/17/2009 18:22:47 route,event,debug index=11520
Sep/17/2009 18:22:47 route,event,debug caps=408c
Sep/17/2009 18:22:47 route,event,debug status=<LINK,UP>
Sep/17/2009 18:22:47 route,event,debug mtu=1400
Sep/17/2009 18:22:47 route,event,debug lname=ppp198
Sep/17/2009 18:22:47 route,event,debug uname=
Sep/17/2009 18:22:48 pptp,ppp,info : terminating… - call cleared
Sep/17/2009 18:22:48 route,event,debug Interface change
Sep/17/2009 18:22:48 route,event,debug id=146160
Sep/17/2009 18:22:48 route,event,debug index=11520
Sep/17/2009 18:22:48 route,event,debug caps=408c
Sep/17/2009 18:22:48 route,event,debug status=
Sep/17/2009 18:22:48 route,event,debug mtu=1400
Sep/17/2009 18:22:48 route,event,debug lname=ppp198
Sep/17/2009 18:22:48 route,event,debug uname=
Sep/17/2009 18:22:48 route,event,debug Remove interface
Sep/17/2009 18:22:48 pptp,ppp,info : disconnected
Sep/17/2009 18:22:48 route,event Down
Sep/17/2009 18:22:48 route,event Interface=
Here normal connection:
Sep/17/2009 18:22:31 pptp,ppp,info : waiting for call…
Sep/17/2009 18:22:33 pptp,ppp,info : authenticated
Sep/17/2009 18:22:33 pptp,ppp,info : connected
Sep/17/2009 18:22:33 pptp,ppp,info,account xxxxx8 logged in, 10.8.2.36
Sep/17/2009 18:22:33 route,event,debug Interface change
Sep/17/2009 18:22:33 route,event,debug id=146159
Sep/17/2009 18:22:33 route,event,debug index=11519
Sep/17/2009 18:22:33 route,event,debug caps=408c
Sep/17/2009 18:22:33 route,event,debug status=<LINK,LINKOK,IPSUPPORT,UP>
Sep/17/2009 18:22:33 route,event,debug mtu=1460
Sep/17/2009 18:22:33 route,event,debug lname=ppp167
Sep/17/2009 18:22:33 route,event,debug uname=
Sep/17/2009 18:22:33 route,event Up
Sep/17/2009 18:22:33 route,event Interface=
Sep/17/2009 18:22:33 route,event Link up
Sep/17/2009 18:22:34 route,event,debug Address change
Sep/17/2009 18:22:34 route,event,debug local=168296705
Sep/17/2009 18:22:34 route,event,debug id=118366
Sep/17/2009 18:22:34 route,event,debug iface-id=146159
Sep/17/2009 18:22:34 route,event Added candidate route
Sep/17/2009 18:22:34 route,event DstAddress=10.8.2.36/32
Sep/17/2009 18:22:34 route,event Attributes
Sep/17/2009 18:22:34 route,event protocol=CONNECT
Sep/17/2009 18:22:34 route,event scope=10
Sep/17/2009 18:22:34 route,event targetscope=0
Sep/17/2009 18:22:34 route,event connet= address=10.8.1.1 netmask=255.255.255.255 ifaceIdx=11519
EN: At quantity of dynamic addresses (connections) 200 ros refuses to accept a login of the subscriber, accordingly on billing leaves pptp-0 and is refused through a package from radius. Though there are doubts in correctness of the first logs, in ppp quickly there is a login of the subscriber with 0.0.0.0 address, and the radius on billing transfers Framed-IP on ros. Errors in logs of billing and radius are not present.
RU: при количестве динамических адресов (соединений) 200 ros отказывается принимать логин абонента, соответственно на биллинг уходит pptp-0 и получает отказ через пакет от радиуса. Хотя есть сомнения в правильности первого лога, в ppp кратковременно появляется логин абонента с адресом 0.0.0.0, а радиус на биллинге передает Framed-IP на ros. Ошибок в логах биллинга и радиуса нет.
are you sure you have enough ip addresses to assign?
status=<LINK,UP>
vs
which version of routeros ?
pool address 10.8.1.2-10.8.2.254
version 3.28
I am sorry. The problem is solved. Failure had appeared “sleep” sessions on radius.
