I have a MikroTik hAP AC RouterBoard, Triple Chain Access Point 802.11ac (RB962UiGS-5HacT2HnT-US).
I want to change the configuration to use it as a router connected to my cable modem, but I want the WAN port to be ether5 as opposed to the default configuration ether1. I also want the router to have 192.168.98.1 IP address and DHCP server on LAN and obtain the IP address automatically from WAN.
I used Winbox to swap ether1 and ether5 in all appropriate places in the default configuration but can’t connect to the router while plugged into either of ether1-ether4 ports and navigating to 192.168.98.1
Here is my current configuration. Any advice will be very appreciated.
[admin@MikroTik] > export compact
# jan/02/1970 00:39:01 by RouterOS 6.46.2
# software id = KRZN-YWXP
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7D08A72F8A
add admin-mac=[hidden] auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=profile1 supplicant-identity="" \
wpa-pre-shared-key=[]hidden] wpa2-pre-shared-key=[hidden]
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge security-profile=profile1 ssid=Lastochka-2G wireless-protocol=\
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
ap-bridge security-profile=profile1 ssid=Lastochka-5G wireless-protocol=\
802.11
add name=dhcp ranges=192.168.98.10-192.168.98.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add interface=ether5 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether1 list=LAN
add interface=sfp1 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
add address=192.168.98.1/24 comment=defconf interface=ether2 network=\
192.168.98.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether5
add address=192.168.98.0/24 comment=defconf gateway=192.168.98.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.98.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
Thanks. This pointed me in the right direction. I was able to make it work (and the reason I needed WAN on port 5 is because that port provides POE and I wanted to power my WiFi Booster - Mikrotik Metal 52 to amplify an external WiFi signal from the shore, - it is mounted on the sailboat stern arch.)
Below is the working configuration where Mikrotik Router is set up as an Access Point with ports 1 to 4 and both WLAN’s assigned to LAN, and port 5 assigned to WAN. DHCP client on WAN, DHCP server on LAN. Firewall rules are the same as from the factory. Both WLAN’s have been secured. No configuration changes other then admin password has been made to Mikrotik Metal 52.
[admin@MikroTik-Router] > export
# feb/06/2020 15:09:40 by RouterOS 6.46.2
add admin-mac=<hidden> auto-mac=no comment=defconf name=bridge
allowed mode=dynamic-keys name=Lastochka supplicant-identity="" \
wpa-pre-shared-key=<hidden> wpa2-pre-shared-key=<hidden>
/interface wireless
disabled=no distance=indoors frequency=auto mode=ap-bridge \
security-profile=Lastochka ssid=Lastochka_2G wireless-protocol=802.11
security-profile=Lastochka ssid=Lastochka_5G wireless-protocol=802.11
/ip hotspot profile
add comment=defconf interface=ether5 list=WAN
add address=192.168.98.1/24 comment=defconf interface=bridge network=\
192.168.98.0
/ip dhcp-client
/ip dns static
invalid
invalid
/system clock
set time-zone-name=America/New_York
/system identity
set name=MikroTik-Router
/tool mac-server
