It seems that mikrotik doesn’t support this right now. As we are unable to setup mikrotik as LNS because we have just one problem: That is how to setup l2tp tunnel authentication.
We want to know if mikrotik plan to support this feature ?
As You , we are very interested for implementing that feature on Mikrotik too.
If somebody from mikrotik can discuss this implementation, it will be excellent.
Somebody ?
you simply want to use radius for l2tp-server authentication - so you dont have to use ppp secrets? Maybe I am missing something.
Yes, you are…
VPDN Cisco tehnology need that you have L2TP Tunnel Authentication on your LNS. So if you have mikrotik as router and LNS and at the other side you have CISCO (unfortunately in my case other side is CISCO) this is impossible to set as mikrotik doesn’t support it.
More info you can find here about this: http://www.cisco.com/warp/public/cc/pd/iosw/tech/l2pro_tc.htm
Somebody to discuss ?
we´re experimenting with this issue at this time.
in our experiments we´re half-successfull with “no l2tp tunnel authentication” on a LNS in the middle.
but it seems that mikrotik only supports 1 ppp session per l2tp tunnel ![]()
Yes, mikrotik doesn’t see different id tunnel connections. So, if you have one vpdn connection from one LAC, and receive another from the same LAC (with different tunnel id or with the same tunnel id), mikrotik disconects previous connection. So, this is main trouble if you shut down l2tp tunnel authentication on LAC.
If you have Cisco router, you can have as many as you want connections from the same LAC. That connections also can have the same tunnel id and works without a problem.
It will be excellent if Mikrotik can use this tehnology in next routerOS releases:
