Problem NetInstall Trying to Install ROS to CF For WRAP2
Hello Group…
I have been following a couple forum posts for installing ROS onto CF for WRAP2 Boards:
http://www.quest4.org/etc/routeros-wrap.htm
http://forum.mikrotik.com/t/install-mikrotik-on-wrap-2e-via-netinstall/11656/4
To begin with I am using an XP laptop which has a CF Read/Write drive built-in.
In following the instructions on the first of the two links above once I open NetInstall and direct it to the localized installation files I see all of the file for the x86 package.
There are no CHECKBOXES to the left of any of the packages only what appears to be a bag “package”?
Anyhow if I select the “System” package then select the drive to install to all of the packages vanish from the Packages list, what’s weird is I have to close NetInstall and re-open it to make the Packages re-appear.
Has anyone run into this problem or maybe you know what the problem is I would appreciate input as I have tried this numerous times to all be met in failure to install ROS onto a CF.
Thanking you in advance for your help with this.
Best Regards
You need to first select the target drive for the installation in the top-left window, and THEN browse for the packages with the browse button
Thank you very much for the reply normis…
I just tried selecting the target drive first as suggested then browse for the x86 package.
No files are displayed though even after I point NetInstall to the file location :confused:
So if I press Install NetInstall complains that I have not selected no packages…
Thanking you in advance for your further help.
Best Regards
do you use the latest Netinstall?
Thank you for the reply Chupaka…
I was running 3.20 and just updated to 3.22 and viola!
Thank you very very much! :smiley:
Best Regards
I have been trying to finalize the installation of ROS onto the WRAP 2 board, but seem to be having problem…
The present settings on the WRAP board are:
*9* 9600 baud (3) 38400 baud (5) 57600 baud
(C) CHS mode *L* LBA mode
(E) Etherboot enable
(U) USB enable
(D) Conservative DRAM timing
*R* Serial console enable
(X) Xmodem upload (Q) Quit
After making the above changes to the WRAP board and also setting my terminal to 9600 8-N-1 I then power cycle the board and it only displays the following never going onto the:
Welcome to MikroTik Router Software hard disk installation
Press Ctrl-Alt-Delete to abort
130048 KB Extended Memory
01F0 Master 848A SanDisk SDCFB-64
Phys C/H/S 490/8/32 Log C/H/S 62/32/63
I feel I am missing something here quite possibly, could someone help to shed a little light on this subject for me?
Thank you
Best Regards
