Hi friends
My problem is I want to reset my RouterOS in the other side by telnet, reset it on default configurations,
because I can’t connect to it directly using winbox (MAC address or IP)
and thanks
Hi friends
and thanks
can you connect with Telnet? if yes, “/system reset” will default the config
