I contact you about a weird problem with a wireless link between 2 QRT-5 (routeros : v6.22 on both)
When I ping the station from the AP I have packet loss, it s pretty irregular, no loss for 30 seconds, then loss for 4/5 seconds, then no loss again, then loss for 10 seconds, etc…
I first check my wireless link, but it seems that the problem doesn’t come from it :
Signal : -39/-39 dBm
CCQ : 97/98%
TX/RX rate : 300/300 Mbps
Physical distance between devices : 50m
I tried different frequencies and still have my problem.
I tried a lot of different settings (AP Bridge => station / AP Bridge => station bridge / an actually AP Bridge => station WDS).
I also tried to enable the wireless-fp package on the AP (was afraid to lose link with the station) and it is worse (70/80% loss).
I was losing hope when I find something.
If I ping the AP from the station, I don’t have any packet loss.
And if I ping the AP from the station and the station from the AP, no packet loss on any ping.
So for the moment both sides pings save me but that’s not really a good solution ![]()
AP wireless advanced export :
name="wlan1" mtu=1500 mac-address=4C:5E:0C:80:9B:FD arp=enabled disable-running-check=no interface-type=Atheros AR9300 radio-name="4C5E0C809BFD"
mode=ap-bridge ssid="R1A1C5-PTP" area="" frequency-mode=regulatory-domain country=france antenna-gain=14 frequency=5320 band=5ghz-a/n
channel-width=20/40mhz-ht-below scan-list=default wireless-protocol=802.11 rate-set=default
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007 distance=dynamic
tx-power-mode=default noise-floor-threshold=default nv2-noise-floor-offset=default periodic-calibration=default periodic-calibration-interval=60
dfs-mode=none wds-mode=dynamic wds-default-bridge=bridge-local wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=yes security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-
20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=advanced multicast-helper=default multicast-buffering=enable
Station wireless advanced export :
name="wlan1" mtu=1500 mac-address=4C:5E:0C:80:9B:23 arp=enabled disable-running-check=no interface-type=Atheros AR9300 radio-name="4C5E0C809B23"
mode=station-wds ssid="R1A1C5-PTP" area="" frequency-mode=regulatory-domain country=france antenna-gain=24 frequency=auto band=5ghz-a/n
channel-width=20mhz scan-list=default wireless-protocol=any rate-set=default
proprietary-extensions=post-2.9.25 wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
mcs-20,mcs-21,mcs-22,mcs-23
Il also enable debug logs and i can’t see anything.
Any idea ?
(Il also send this message to support@mikrotik.com)
Thanks,
