Hello everybody,
I have RB201 1UI AS-RM and i want make QoS to differenciate VoIP, Data and P2P.
Here is my configuration:
/ip firewall mangle
/////////VoIP\\\\
Add chain=prerouting action=mark-packet new-packet-mark=VoIP port=5060 protocol= tcp passthrought=yes comment=”sip”
Add chain= prerouting action=mark-packet new-packet-mark=VoIP port=5060 protocol=udp passthrought=yes comment=”sip”
Add chain= prerouting action=mark-packet new-packet-mark=VoIP port=5004 protocol= udp passthrought=yes comment=”RTP”
Add chain= prerouting action=mark-packet new-packet-mark=VoIP port=4569 protocol= udp passthrought=yes comment=”IAX”
Add chain= prerouting action=mark-packet new-packet-mark=VoIP port=5036 protocol= udp passthrought=yes comment=”IAX”
Add chain= prerouting action=mark-packet new-packet-mark=VoIP port=3478,3479 protocol= udp passthrought=yes comment=”STUN”
Add chain= prerouting action=mark-packet new-packet-mark=VoIP port=10000 protocol= udp passthrought=yes comment=”STUN”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=80 protocol= tcp passthrought=yes comment=”HTTP”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=443 protocol= tcp passthrought=yes comment=”HTTPS”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=22 protocol= tcp passthrought=yes comment=”SSH”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=53 protocol= tcp passthrought=yes comment=”DNS”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=53 protocol= udp passthrought=yes comment=”DNS”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=20,21 protocol= tcp passthrought=yes comment=”FTP”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=110 protocol= tcp passthrought=yes comment=”POP3”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=25 protocol= tcp passthrought=yes comment=”SMTP”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=143 protocol= tcp passthrought=yes comment=”IMAP”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=993,995 protocol=tcp passthrought=yes comment=”SSL”
Add chain= prerouting action=mark-packet new-packet-mark=Data port=546 protocol=udp passthrought=yes comment=”DHCP"
Add chain= prerouting action=mark-packet new-packet-mark=P2P port=6881-6889 protocol=tcp passthrought=yes comment=”BitTorrent”
Add chain= prerouting action=mark-packet new-packet-mark=P2P port=6881-6999 protocol=tcp passthrought=yes
Add chain= prerouting action=mark-packet new-packet-mark=P2P port=27763 protocol=tcp passthrought=yes
/ queue tree
Add name= ‘QueueVoIP packet-mark=VoIP priority=2 parent=ether2 limit-at=0 disabled=no max-limit=xx
Add name=QueueData packet-mark=Data priority=7 parent=ether2 limit-at=xx disabled=no max-limit=xx
Add name= QueueP2P packet-mark=P2P priority=7 parent=ether2 disabled=no max-limit=1024k
I ouput ether3, eher4 and ether5 of the bridge-local and I placed ether2 in master-port with ether3 ether4 and ether5 in slave.
I connect my PC to ether5 and ether2 to the WAN.
To test if my QoS run, I dowload some files but my dowload going up to 6M/S while i dont’t want the flow exceeds 1024k.
Where is the problem and can you help me to solve him ? And if you see some errors in my configuration
To dowload, I use Vuze with listen port 27763 ( just to see if the QoS run).
Sorry if my english isn’t good but i’m french.
Thanks a lot !
