problem opening games
Greetings, I need some urgent help, my problem is not critical, but it turns out that I navigate perfectly, but when I try to play League of Legend and Tibia, the client does not load, the Tibia client tells me Tibia is currently down for maintenance, but if I use a vpn there if it opens normally and there are days that it works perfect, it should be noted that I have a hotspot and some antennas connected, if you could help me with it I would greatly appreciate it since I do not have the knowledge or the money to pay a technician solve this for me
First you make sure that the problem is not from your ISP, you make a test with a direct connection from your ISP to your PC (without any personal equipment).
If all is ok you tell us how everything is connected and provide sanitized setting exports and maybe someone can help you, for free, in their spare time.
Cheers!
